EFI Relearn?
Old Apr 27, 2010 | 03:15 PM
Crywolf's Avatar
EFI Relearn?
I've searched both here and 4runner.org trying to figure out a little problem of mine. I just cleaned my throttle body, replaced the pcv valve and tightened all my throttle body cables. While this was all being done I had the efi fuse pulled. Reassembled everything and fired up the truck, it runs great only one issue, it seems to be idling at roughly 1500 rpms. I backed off all the cables to their original positions but the problem remains, the truck drives fine though. 98 4runner 3.4. Any ideas?
Old Apr 27, 2010 | 03:57 PM
scuba's Avatar
Is 1500 a cold idle or a warm idle? If cold let it warm and see what it drops to, should be in the 750-900 range iirc.
If it drops to that range once warm, I'd say you're fine and give the truck about 100 miles before you think you messed anything up.
Old Apr 27, 2010 | 04:10 PM
Crywolf's Avatar
That's at warm idle, however I started the truck and only drove a few miles then shut it down, I'll try a longer drive (15 min or so) and see what happens.
Old Apr 27, 2010 | 07:18 PM
MillerPKA's Avatar
There have been multiple reports of this happening, most notably when cleaning the throttle body. Some have claimed that somewhere in the cleaning process it alters the idle and so far the only solution some have found is to go buy a used throttle body. Keep the thread updated with your results.
Old Apr 27, 2010 | 08:19 PM
Crywolf's Avatar
Well THAT isn't what I wanted to hear! haha Well it runs fine down the road, just idles a bit high when in park. I'm not gunna worry about it too much though, it gets crazy cold here in Iowa during the winter so if nothing else it will just lessen my warm up time in January!
Old Apr 27, 2010 | 08:28 PM
Crywolf's Avatar
Hmmm, thinking out loud here but what if I inadvertently toasted my IAC valve with the cleaning chemical? Wouldn't that adversely affect only the trucks idle?
Old Apr 29, 2010 | 09:05 AM
Crywolf's Avatar
Solved!
Ok just an update I found a solution to my high idle problem. It was in fact the IAC on the bottom of the throttle body. I think when cleaning the tb some gunk worked its way down in there and the IAC had become stuck. I removed the IAC, cleaned it thoroughly, and reinstalled it. Problem solved! Here is the link I used as a guide. https://www.yotatech.com/forums/f123...ac-pics-92286/
Old Apr 30, 2010 | 12:47 PM
85 PICKUP's Avatar
I did the same cleaning you did and mine ran similar. It took a little driving around to get it to self adjust to a reasonable idle.
Gutted91
Jan 3, 2020 09:48 AM
mreagen
Oct 5, 2015 04:27 PM
rmill05
Sep 27, 2015 01:43 PM
Boomer8404
Sep 20, 2015 06:15 PM
themightykhoner
Sep 18, 2015 02:28 AM
