97 4Runner Light next to gear shifter broken
Old Apr 22, 2010 | 04:28 PM
Skizor1337's Avatar
I no this is random but there should be a little light near the gear shifter im pretty sure. and mine is broken does anyone no how to replace them?
heres a link to show where it is at
http://images2.auction123.com/ad25cf...g?webimage001l
its right above the P there is like a little opening. im pretty sure a light works there. if im wrong someone tell me. But if anyone knows how to fix or where to replace reply quick. Thanks
Old Apr 22, 2010 | 04:58 PM
JWaldz's Avatar
well, that little opening is actually for the tab that you push where you can switch your transmission to different gears with the truck off. Regardless, yes there should be a light that lights up the gear lettering/numbering. How you get to it is beyond me, but someone ought to know around here. I believe it's a #74
Old Apr 22, 2010 | 05:23 PM
stockwell45's Avatar
getting to the bulb is a piece of cake, just unscrew the 4wd shifer knob, pull off the console cover, then there are like 3 screws holding the shifter plate on, take those out and then you can pull the shifter lettering off. underneath it is wires, and they go to the bulb. just twist the bottom of it and it will come out
Old Apr 22, 2010 | 05:29 PM
Skizor1337's Avatar
what u mean #74? i need to either get a replacement part or fix it.
How do i do that or where can i get the part?
Old Apr 22, 2010 | 05:39 PM
JWaldz's Avatar
that's what the bulb type number is.. Here, I google shopped it for ya haha
Click Me
voiddweller
19
May 2, 2016 09:10 PM
odonekanobe
Jun 26, 2015 02:27 PM
streetuner15
Jun 18, 2015 10:59 PM
Mohamed
Jun 20, 2002 10:42 AM
