Need tranny advice
Old Apr 26, 2010 | 03:11 PM
jinos's Avatar
Need tranny advice
Hello Yota folks. I recently purchased a 98 4runner (about a year now) and love it! Noticed it having some issues. It seems to not catch gear until 2-2500rpm once in awhile after I put it in drive. So I checked the fluid and it's still pink which was change 1 1/2 year ago. What could it be? Is it a sensor? I keep hearing from people to change the fluid but wanted to hear your advice first. Any help is greatly appreciated. It's a 2WD limited.
Old Apr 26, 2010 | 04:23 PM
brian2sun's Avatar
It could be a bad shift solenoid, or the tranny might just be wearing out and on it's last leg. Usually, changing the fluid is the 1st and least expensive step and many times that solves the problem. Are you sure the fluid isn't just low? That could also cause rough shifting.
Old Apr 26, 2010 | 04:33 PM
mt_goat's Avatar
ATF level checked ok?
Old Apr 26, 2010 | 06:58 PM
jinos's Avatar
Checked the fluid level a dozen times and its the same. I'll change the fluids and see what happens. How long does a tranny last? I bought it from the original owner and took very good care of it. has 195K but on a full rebuild. Hopefully just that or solenoid. Thanks.
Old Apr 27, 2010 | 04:32 AM
gdutch's Avatar
Can't hurt to flush the ATF; certainly cheaper than having it opened up right off the bat.
Old Apr 27, 2010 | 09:28 AM
iselloil's Avatar
If its cold it wont shift until it gets to a certain temp
Old Apr 27, 2010 | 09:58 AM
jinos's Avatar
It does it when it's warm also. Gonna do the flush this weekand. Hope it works.
1uzRunner
63
Nov 10, 2018 03:58 PM
wberry85
Apr 6, 2018 08:45 AM
eggens
Sep 5, 2015 12:16 AM
DiggnDeep
Sep 3, 2015 02:45 PM
Nick Berg
Sep 3, 2015 04:36 AM
