ebay timing kit has arrived
Old May 10, 2010 | 12:00 PM
Elton's Avatar
well if some of you don't know my water pump seized up last week it was factory with 188k ... i couldn't afford oem everything but i wanted to replace everything so i did some research and deiced to go with a kit from here bungerfeldsauto
some how i got a oem upper rad hose though but rest is some good stuff
Old May 10, 2010 | 12:56 PM
Mauzer's Avatar
subscribed
Old May 11, 2010 | 08:58 PM
Elton's Avatar
got a home made crank pulley tool made just need a few tools and my friend to not be so busy and should be done this week
Old May 11, 2010 | 09:15 PM
PismoJoe's Avatar
NICE!!! You've got some quality parts there. Not too many people know that Bando is OEM for Toyota, hope you get it on soon!
Old May 11, 2010 | 11:54 PM
Elton's Avatar
really well that makes me feel better
Old May 12, 2010 | 09:10 AM
Tubbyfatty's Avatar
Elton, didnt you do your timing belt a while ago?
Old May 12, 2010 | 10:01 AM
Cbohl51's Avatar
Hey, this is the same kit that showed up on my door step last week. Heck of a deal from that seller on Ebay.
Good Luck with your install! Will be attempting mine in about a week.
Old May 12, 2010 | 10:39 AM
Elton's Avatar
na it looked great when the water pump went it melted some of the belt
Old May 13, 2010 | 11:20 PM
Elton's Avatar
gonna try and finish tonight got everything i think i need ... i cant wait !!!
Old May 14, 2010 | 05:09 AM
LifeOnABoard's Avatar
Call me crazy but wouldn't it be a good idea to at least use an OEM water pump? I think that's the one thing I'd want to make sure is highest quality possible, but that's just me. I bet they're expensive!
Old May 14, 2010 | 05:15 AM
vital22re's Avatar
totally a bro
aisin is oe... its who toyota used... Just doesn't come with the box that says toyota on it. Looks like most of the parts are oe.
Old May 14, 2010 | 07:24 AM
Good to know, thanks!
Old May 14, 2010 | 09:04 AM
PismoJoe's Avatar
Yup Aisin grinds off toyota's stamp if you buy aftermarket oe parts...strange huh?
Old May 14, 2010 | 11:55 PM
Elton's Avatar
its done as of 12am man im excited everything fit great so far it runs perfect only drove it a few miles though... a few notes the lower idler takes a 10mm allen and the crank pulley i had to use a puller it was stuck on good.....
Old May 15, 2010 | 06:48 AM
TheDurk's Avatar
Congratulations! It feels good when it fires up and purrs after surgery like that...
I was lucky, my pulley came off by hand. And now it has anti-seize on it.
How did you break the crank bolt? Starter bump or brute force? (I bumped.)
Old May 15, 2010 | 07:26 AM
Elton's Avatar
old school 1/2'' mac air gun at 120 psi here's the tool me and my friend made
Old May 16, 2010 | 09:55 PM
Elton's Avatar
its running great no leaks no weird sounds its not the hardest job in the world just takes awhile or if your close to me ill do it for a reasonable price
Old May 16, 2010 | 10:11 PM
BigBluePile's Avatar
Nice job Elton!!!
Old May 17, 2010 | 06:01 PM
Elton's Avatar
o and if you dont got a torque wrench that does at least 200ft lbs borrow one or buy one
Old May 17, 2010 | 06:20 PM
TheDurk's Avatar
250 is more like it. (217 ft-lbs. spec on the crank bolt on my truck)
