1.5- 2 mpg increase
Old May 1, 2010 | 04:21 AM
wrpsuite's Avatar
1.5- 2 mpg increase
Cleaned MAF, New Purolator Air Filter (clogged with invisible pollen) and switched over to Synthetic .. every little bit helps, it was my first >18mpg tank in 2 months... was down to 16-16.5 prior.
Old May 1, 2010 | 07:36 AM
NickP's Avatar
Im about due for all that stuff myself. Im actually going to do the big overhaul here in about a month (water pump, timing belt, full tune up, fuel filter, ect...)
Hopefully i will see some gains also. With my new 33's im down to 16's also lol
Old May 1, 2010 | 07:37 AM
PismoJoe's Avatar
What year and model is your car? V6, I4?
Old May 1, 2010 | 08:43 AM
BajaRunner's Avatar
Did you take out the 200lbs of sand bags in the back? That usually helps my MPG
Old May 1, 2010 | 01:24 PM
wrpsuite's Avatar
01 4wd v6 ... imagine if I pump up the tires I'll really be saving the environment!
Old May 1, 2010 | 04:01 PM
DailyDrive's Avatar
If you pump up tires to where you will be getting an improvement in mileage, you will just wear them in the center faster. Extra mileage will come from the fact that you effectively just put the same weight on a smaller contact patch.
Anybody getting any tires soon? There are some low weight and low rolling resistance 600+ treadwear tires coming out now. Now those things in a 255 or less width should give a real MPG jump in city driving.
Old May 1, 2010 | 05:47 PM
eddieleephd's Avatar
too low of pressure vs the right pressure will eat your gas and a little extra air does not hurt your tires that much!!
Old May 2, 2010 | 06:04 AM
NickP's Avatar
Ive also heard winter air is heavier than summer air, any truth to this? (j/k)
On a lighter note, im running 255/75's instead of the 275/65's and still ended up loosing MPG just because of rotational mass, so take that into consideration when buying tires if your souly going for MPG
Old May 2, 2010 | 06:17 AM
ok by running a smaller wheel you will lose MPG if the circumference is smaller the ratio is off!!! So yeah this is a negative effect...
Old May 2, 2010 | 07:02 AM
VANCE164's Avatar
runnning the correct air pressure is essential too much and youll wear the center too little and youll wear your edges off faster id say with 33s id run around 28-30 psi you'll wear evenly at about 35psi just make sure and keep them rotated about every 5 thousand.
Old May 2, 2010 | 06:51 PM
NickP's Avatar
As was already said it wouldnt effect anything but the speedo (and maybe 100 rpm) However im running taller tires than the stockies, not smaller.
Old May 3, 2010 | 08:41 AM
I guess I misunderstood I know some were meant to run 265/75/r15 and was thinking yours may be one...
sometimes a slight increase in circumference will increase the fuel mileage but decrease available HS.PWR.
Old May 7, 2010 | 11:53 AM
wrpsuite's Avatar
on top of the above mentioned maintenance items this week I ran a bottle of sea foam in with the gas and this thing is running sweet
Longbed 90
Mar 11, 2019 12:38 PM
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
kawazx636
Sep 29, 2015 08:22 AM
moparbay
Sep 3, 2015 12:48 PM
