What's that thump?
Old Dec 16, 2008 | 10:50 PM
wsudu's Avatar
What's that thump?
It seems like I have been feeling a thump when I am rolling say at 60 with no gas, then when I floor it for a sec I can feel a thump. I don't feel it when I am at a light and let off the brake and give it gas. It is almost as if there is play somewhere in the drive line and when I give it gas I can feel it. It also seems like it was been getting a little worse in the last year. I also think it seems worse in 4x4. Any ideas as to what it is or should I be concerned? It isn't terrible but it is noticeable.
Old Dec 16, 2008 | 11:52 PM
TNRabbit's Avatar
Put it up on blocks in neutral & very carefully inspect the u-joints. That's where I'd start....
Old Dec 17, 2008 | 01:24 PM
desertcox05's Avatar
+1 on u-joints
Old Dec 17, 2008 | 01:34 PM
Tacoclimber's Avatar
Possibly your CSB. Check that and your u-joints.
Old Dec 17, 2008 | 01:35 PM
Ed H.'s Avatar
my truck did that because of the carrier bearing, im not sure if you have one or not. jack it up and wiggle some stuff
Old Dec 17, 2008 | 01:47 PM
CSB= Center Support (Carrier) Bearing
The CSB shouldn't have much (if any) play in it. If it does, when torque is applied, it will cause the driveline to "thump" against the bearing bracket.
If it is the CSB, I have a CSB that I bought, then got a deal on the whole upper driveshaft, including a CSB. It's been laying in my garage, and if you need one, I'll make you a deal.
Old Dec 22, 2016 | 07:25 AM
Howler2703's Avatar
accelertion thump
I have a 96 taco SR5 4wd that has a thump when accelerating and at speed also. When at a light or at idle no thump and when I take my foot off the gas the noise reduces at the truck slows down.
I will have to check the CSB. If it is that, it will be awesome. I will probably go ahead and replace the U-joints while I am at it too.
Old Dec 23, 2016 | 06:36 PM
sharrack's Avatar
Center bearing.....they all die.
Dakotaneu
Aug 15, 2015 07:24 AM
Mister Willie
Jun 20, 2007 09:32 PM
jiffy55
Oct 2, 2006 07:37 PM
1997_4Runner
Oct 12, 2004 04:52 PM
Brett605
Apr 30, 2004 12:02 PM
