3.4L Toyota Part Numbers
Old Dec 30, 2008 | 09:53 AM
TRDPARTS4U's Avatar
FormerVendor
Common parts on Taco and 4R 3.4L We'll keep adding part numbers as we have time to research them.
13568-69095 BELT, TIMING
13503-62040 IDLER SUB #2
13505-62070 IDLER SUB #1
13540-62021 TENSIONER
90311-38051 SEAL, CAM
11213-62020 GASKET, VALVE COVER
11193-70010 GASKET, SPARK PLUG TUBE
90311-40022 SEAL, CRANK
90916-03075 THERMOSTAT
16325-62010 GASKET, THERMO
16100-69398-83 WATER PUMP
Old Jan 4, 2009 | 10:31 AM
Ron Helmuth's Avatar
thanks guys this is helpful so we have a "real" resource
appreciate the postup
Old Feb 27, 2009 | 10:47 AM
TRDPARTS4U's Avatar
FormerVendor
90080-91090-83 Belt, fan-alt
90080-91126-83 Belt, pwr steering
99364-20870-78 Belt AC
90919-01192 Spark plug
19037-62010 Spark plug cables
90915-YZZD1 Oil filter
90430-12031 Gasket, oil drain plug
17801-07020 Air filter
Old Feb 27, 2009 | 01:12 PM
raydouble's Avatar
90119-16006
Crnkshft damper - Bolt
3.4 liter 2000 - 2004
Old Feb 27, 2009 | 02:00 PM
TRDPARTS4U's Avatar
FormerVendor
Originally Posted by raydouble
90119-16006
98-04 on Tacomas
98-02 on the 4 Runners
Old Feb 27, 2009 | 02:15 PM
oddjob1370's Avatar
3rd gen 4runner - not sure what each part is but this is everything you need for the Sports hood minus the actual hood.
Hood Scoop Parts
78181-35901 $97.01
76181-35020 $11.59
76183-12030 $.66
76184-12020 $.66
76185-35010 $5.99
90269-04054 x2 $.57 each
75567-21030 x4 $.94 each
90167-45005 $.66
90179-06324 x6 $1.94
Nozzles and Hoses
85381-12050 x2 $13.88 each
85377-35240 $.91
85377-32220 $.85
85348-12250 $.66
90999-33080 $5.54
Heat Shield and clips
53341-35032 $160.07
90467-09006 x 11 $.62 each
Note - this is Northridge Toyota prices with the 20% off
Old Mar 3, 2009 | 10:29 PM
raydouble's Avatar
Starter solenoid rebuild parts
Plunger magnet switch 28235-54380
Kit starter repair 28226-54340 (contact, bolt, o-ring, paper and plastic pieces) larger bolt/contact
Starter kit 28226-72010 (contact, bolt, o-ring paper and plastic pieces) smaller bolt/contact
Old Mar 4, 2009 | 06:24 AM
warriors_03's Avatar
So last week I stumbled onto http://www.toyodiy.com/parts/q.html. Its the holy grail of part numbers for toyota's. Its searchable by VIN or Model Drill down. I hope this helps anyone who is looking for the OEM specific part numbers in the future.
Old Mar 5, 2009 | 09:25 AM
Bphillips0309's Avatar
Got a part number for the Under Engine Guard bolts? Took my 02 into the dealership a year ago and it came out without them...the dealerships insists that they were already off when I brought it in. Long story short I can't find a replacement part number. right now it's zip tied up...
Old Mar 5, 2009 | 10:20 AM
raydouble's Avatar
90119-08A33
x 9 total both skidplates (5 front, 4 rear)
Edit: superseded by part # 90080-11373
Old Mar 5, 2009 | 10:39 AM
raydouble's Avatar
Not strictly for the 3.4L but good to know.........
FIPG (form in place gasket)
Orange
00295-01281
Black
00295-00103
Old Mar 19, 2009 | 04:53 AM
97ltd4x4's Avatar
99 4runner 4x4,limited 3.4/auto part #'s
Rear driveshaft U-Joint kit: 04371-60070
IAC VALVE gasket: 22215-62180
IAC VALVE: 22270-62050
Old May 23, 2010 | 10:35 PM
raydouble's Avatar
Anyone know the OEM part number for a power steering rebuild kit?
94 Newbie
Jul 6, 2015 04:23 AM
bprice0077
Jun 25, 2015 07:36 AM
Chooch
Jun 19, 2015 03:05 PM
TheManOutside
Jun 18, 2015 03:32 PM
ShaunKris
Jun 17, 2015 04:33 PM
