What gears do I have??
Old Dec 11, 2008 | 04:01 PM
Sea.Jay's Avatar
2002 4runner...complete base model SR5 2 wheel drive.
One sight is saying 3.73s and another guy is saying either 3.90, 4.10, or 4.30.
I need new gears but can't decide because I don't know what size stock I have!
- Chris
Old Dec 11, 2008 | 04:33 PM
crolison's Avatar
what tires are you going with?
Old Dec 11, 2008 | 05:21 PM
Sea.Jay's Avatar
31x105ss for now and the next set will be 32x11.5s
Old Dec 11, 2008 | 05:42 PM
crolison's Avatar
I would check car-part.com and go with 4.10's or 4.30's
you can find a used third on that site and just swap it in. I am betting you have 3.90.....
you have the v6 right? if not go with 4.56's
Old Dec 11, 2008 | 07:16 PM
Sea.Jay's Avatar
yeah v6 automatic trans. ring n pinion guy is suggesting 4.88s for a DD and thinks I have 4.10s. spec sheet on the internet is saying 3.73s. called dealer with my vin and is saying 4.10s or 4.11s
- chris
Old Dec 12, 2008 | 03:11 AM
crolison's Avatar
4.88's v6 = 35's
4.56's v6 = 33's
I personally believe you would be way overgear'd with 4.88's on the street with 32's......
Are you going to go any bigger than 32's?
I am running 4.88's with 33's, but i am the 4banger and its a very good combo.
Old Dec 12, 2008 | 06:50 AM
97ltd4x4's Avatar
According to this spec sheet:
http://www.top4runners.com/ja/runhis.../2002specs.pdf
2WD AND 4WD WITH 4ECT
Ratios 1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
Reverse 2.393
Differential Ratio
2WD/4WD 3.727*/3.909*
Transfer Case (4WD)
High 1.00
Low 2.566
*4.100 with optional P265/70 R16 tire package (standard on Limited)
For your vehical 2WD:If you know for sure what size wheels were orginally on vehical:
So if you have 15" wheels= 3.73's
So if you have 16" wheels=4.100's
As standard equiptment.
*They might be hard to find,If so... you could put in 4.100 since they are the most common....BUT,I am not sure about the spline/axle diameter of your 2WD,they might be smaller than the 4.100's...Might have to go with 3.73's,or just find a used complete axle assembly.
Old Dec 12, 2008 | 10:32 AM
crolison's Avatar
the rear is the same on the 2wd and 4wd 4runners..... they don't do what they do in the mini vs regular taco.
Any 8" (preferably v6) third will work in your axle.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
