Who has installed a TRD decal on their 4Runner?
Old Dec 23, 2008 | 05:23 PM
BushPig's Avatar
Question Who has installed a TRD decal on their 4Runner?
I bought some TRD decals to install on the sides of my 4Runner --- the TRD Sport ones.
What have you done with the decal that overlaps onto the gas cap flap?
Looks like half of the decal will end up on the flap... ?
Also, how do prep the surface before installing them? Swab the area with rubbing alcohol?
I'd appreciate any tips, and any close-up photos!!!
Thanks!
Old Dec 23, 2008 | 06:37 PM
VSU_4runnin's Avatar
SEARCH, theres been many posts on 3rd gen TRD.. but it really depends on taste.... ill post some pics tomorow when its light and i can take them.. but heres the other threads....
https://www.yotatech.com/forums/f79/...-build-138353/ (near the bottom, after the BMW pic)
https://www.yotatech.com/forums/f123...-locker-92861/
https://www.yotatech.com/forums/f2/t...16/index2.html
Old Dec 23, 2008 | 06:49 PM
waskillywabbit's Avatar
I've got some "custom" TRD stickers I'm going to install soon.
Old Dec 23, 2008 | 06:56 PM
89needsatranny's Avatar
just one question... any opinions of putting a decal on 1 week fresh paint?? will it hurt?
Old Dec 23, 2008 | 06:58 PM
89--I dont see why it would... after they bake the car its usually fully cured, and im sire the elements would have hurt it already if that were the case.... but im no expert..
ooh sorry bush.. as far as prep.. no one mentioned that.. i cleaned my truck area with soap and water, then dried, alcohol pad, then dried again... theres 2 methods of application, one is dry, start from one and and slowly work your way down or across pressingg it on.. using a credit card or equiv to make sire no bubbles, or 2 put a drop of soap in a squirt bottle fill with water, then spray on surface, position decal then squeegee water out... ive never done this method, so i have no clue how it works... ive just been worried of rouining a perfectly good sticker..
Old Dec 23, 2008 | 07:26 PM
Texas_Ace's Avatar
Ditto what he said as far as prep goes.
As for putting it over the gas cap, look at the link in my sig (pictures are old as the hills but still show you what i did).
I just took my time to lay it out so that the least amount of the decals was over teh gas cap crack. Then layed it ont he truck as if the gas cap was not there, then after it was on i went back and cut the decals and then folded the extra around the edges of the gas cap.
Quite easy, just need ot plan it out so you have the least amount of the decal in the crack or it will look funny.
Old Dec 23, 2008 | 07:30 PM
BMC's Avatar
BMC
I would reccomend putting them on wet. I took an empty windex bottle and put some water and a touch of soap in it and then squirt the place you wish to put the sticker. I also sprayed some on the back of the sticker. This makes it so much easier to install in my opinion because you can move it all around untill you get it exactly where you want it. Then take a credit card and force all the water out. Mine ended up perfectly straight and no bubbles. Ive done other stickers without getting them wet and they didnt turn out so well. Just my .02 cents.
Old Dec 23, 2008 | 07:34 PM
Texas_Ace's Avatar
I agree, i also used this method to install mine and they turned out great.
Old Dec 23, 2008 | 07:36 PM
Rock Slide's Avatar
Click the link in my sig...there's pics there of how my TRD decals look installed. I went over the gas tank lid too.
Old Dec 23, 2008 | 08:43 PM
my TRD is based off of the new tacoma mountain edition (rugged trail edition?) i got it from sock monkey decals and badging He does alot of custom decals that are great. take a look!
Old Dec 23, 2008 | 09:18 PM
Godzilla's Avatar
Looks like he has plenty of graphics. How can these be purchased?
Old Dec 23, 2008 | 09:22 PM
i just created a temporary accnt, and pm'd him.. ill msg him and see if he has another way for us yotatech users
Installation: https://www.yotatech.com/forums/f2/t...llation-65024/
Old Dec 23, 2008 | 09:48 PM
pkt1213's Avatar
Those mountain stickers and sick. I may have to pick me up a set. Now I am trying to decide the color scheme that will go best on a silver 4runner.
How exactly is the sticker set up? Is it clear that's printed on or are they indiviual stickers on something that holds them in the correct position?
Old Dec 23, 2008 | 09:57 PM
hmm I dont know, what colors do they use for a regular trd sticker on a silver taco? do you want it to blend or stick out, if blend then light colors, but stick out use a dark color scheme
Old Dec 23, 2008 | 10:03 PM
pkt1213's Avatar
I'll have to think about it. My main thing is the mountains, I want them to stand out but no look retarded. I like that sticker so much better that the factory tacoma mountian sticker.
Old Dec 23, 2008 | 10:05 PM
the taco one looks good on a taco in person, but with the smalller quarterpannel of a 3rd gen it would have been overbearing.. and i like the way these are as well
Old Dec 24, 2008 | 05:45 AM
X-AWDriver's Avatar
The gas door really isn't an issue;just place it over the gas door like you would the other side then cut the decal with a sharp razor blade and fold the "extra" inside the door.
You are using the dish soap or windex method to install right? It's much easier that way isntead of trying to stick them correctly with the first try.
Old Dec 24, 2008 | 08:14 AM
rimpainter.com's Avatar
Here's a shot of mine:
Old Dec 24, 2008 | 08:45 AM
Wow Christian...I haven't seen you post in ages.
Old Dec 24, 2008 | 08:50 AM
pfdaxe's Avatar
...and you moved from AZ? Guess that's why I haven't seen your truck cruisin' the 101...
