climate control problem
Old Dec 16, 2008 | 07:51 PM
bcoalwell's Avatar
Howdy all, I have a '01 4runner limited and the heater control/ climate control is not working. The vehicle will blow warm or cold air however i cannot turn the ac off ( its stuck on) nor can i switch back and forth between fresh/recirculating air. i removed the unit and tried cleaning everything- did not help. any one know where i can pick one up??
thanks
Old Dec 16, 2008 | 07:58 PM
jkirkendall's Avatar
check a local salvage yard
Old Dec 17, 2008 | 03:25 AM
GSGALLANT's Avatar
I assume that you know this already, but if you have the air direction set to any of the windshield defrost positions, your A/C will be "on" by default and can't be turned off (it helps to clear the fog/dew on the windshield quicker.) At least it's that way on my non-limited 2002 4Runner. Does your limited have auto climate control or manual? If manual, it would be the same as my 2002. I don't think defrost locks out the option to change from fresh to recirc, however.
Old Dec 17, 2008 | 04:17 AM
BigBallsMcFalls's Avatar
from his symptoms, that is def not his problem.
it is likely broken blower box linkage or electronic
Old Dec 17, 2008 | 04:49 AM
GSGALLANT's Avatar
"A/C stuck on" is a common "symptom" among Toyota owners. Turn the air direction knob off of any of the windshield defrost positions and the "problem" goes away, so without better description of the symptoms from the original poster, then yes, that could be his problem (for that part of it).
The fresh air/recirc is a different problem... and he likely doesn't have a linkage for his fresh air/recirc anyways... it is a servomotor. That's where I would start. Remove the air inlet servomotor and test it (apply battery voltage to it directly) to make sure it rotates like it should.
Old Dec 17, 2008 | 06:41 AM
bcoalwell's Avatar
Hey guys thanks for the input, there are a couple of buttons on the control head that don't work- not just the recirculation button. the ac, recurculation, and the outside temp. thinking its the main climate control unit.
Old May 21, 2011 | 08:34 PM
bcoalwell's Avatar
found a good deal on a new climate control head. fixed the problem. thanks
Old May 21, 2011 | 08:39 PM
BoostedRNR's Avatar
Just so ya'll know, this is a very common problem. There is a guy on ebay that will rebuild your existing unit for $150 I do believe. I haven't heard any bad reviews from him and can't wait to send mine off. Much cheaper than a replacement
Old May 22, 2011 | 12:32 PM
bcoalwell's Avatar
thanks for the heads up on the climate control rebuild. mine has just been sitting in the garage. I'm now looking for the power relay for the rear window.
rushw
Jul 18, 2015 01:46 PM
daddio
Jul 18, 2015 10:20 AM
1994toyota
Jul 17, 2015 03:03 AM
sojourner567
Jul 16, 2015 08:52 PM
voiddweller
Jul 15, 2015 03:56 PM
