Hand brake light problem
Old Dec 25, 2008 | 05:50 PM
99yota7's Avatar
The other day after doing a little bit of wheelin i noticed my light on the dash for my hand brake kept randomly coming on and off. It seems like everytime i go over a bump it comes on then a minute later goes off. Anybody know what this is?
Old Dec 25, 2008 | 06:17 PM
crolison's Avatar
low brake fluid, check and fill it up
Old Dec 25, 2008 | 07:50 PM
scuba's Avatar
Check the ground cable on your alternator and battery
Old Dec 25, 2008 | 07:59 PM
the_ocho's Avatar
check your handbreak leaver make sure its down all the way
Old Dec 25, 2008 | 10:06 PM
98runner210's Avatar
low fluid or loose/failing switch
Old Dec 26, 2008 | 10:09 AM
Skrillah's Avatar
low fluid
Old Dec 26, 2008 | 12:25 PM
atistang's Avatar
sometimes my brake light is hard to get to go off when i release my parking brake. i have to keep screwing with it until it goes out, then sometimes if i hit a hard bump it comes back on
but check your brake fluid first, that is probably your cause, and if its low then check all your brakes before you top it off. if you need new pads and you fill it up now, then when you compress the pistons to put new pads on the brake fluid will over flow the reservoir.
Old Dec 26, 2008 | 05:46 PM
you really should be opening the bleeder valve when compressing the pistons. May not be good to be forcing brake fluid backwards through the ABS pump.
Old Dec 27, 2008 | 05:21 AM
atistang's Avatar
i've never done it that way, plus there is no abs pump, its a valve body.
Old Dec 27, 2008 | 06:46 AM
machine23's Avatar
adjust your handbrake assembly. and check the switch
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
