2001 4runner occasional rumbling
Old Apr 6, 2013 | 10:31 AM
dfibslim's Avatar
I get this occasional rumbling lasting 5-10 seconds, not very often, when I'm going around 20mph then resumes to normal. Last time it happened I punched the gas, the rpms didn't increase and it felt as if there was an issue the air/fuel ratio like it was struggling lasting only a few seconds. I have already cleaned the MAF sensor and TB, checked plugs, replaced air filter, computer is not throwing any codes. Any ideas? I'm thinking of replacing the fuel filter.
Also sometimes when I go from reverse to drive the rpms drop to 300-400 and feels like its going to stall just for a second.
Old Apr 6, 2013 | 10:42 AM
Black_1985_SR5's Avatar
Id definitely would change that filter how many miles do you have on it
Old Apr 6, 2013 | 11:30 AM
dfibslim's Avatar
Unknown. Best guess is 260000. Odometer doesn't reflect actual mileage.
Old Apr 11, 2013 | 05:31 PM
dfibslim's Avatar
I just changed the fuel filter with no difference noticed. It still occasionally runs rough at idle but only while in second gear like coasting through a turn or in a parking lot.
I'm planning on checking the resistance through the ignition system wires. Any ideas about what could be causing the trouble?
Flying91
45
Apr 11, 2024 04:39 PM
Sleaker
Aug 26, 2020 06:03 AM
BeMiceElf
Oct 10, 2015 09:40 PM
mengquis
Jul 13, 2015 10:39 AM
Coreyr384
Jul 10, 2015 11:13 AM
