Leaky rear main 5VZ
Old Feb 3, 2013 | 02:54 AM
98 Black SR5's Avatar
Leaky rear main 5VZ
Shop quoted like $800. I know the seal is less than $10. Should I attempt this job myself? I am mechanically inclined. Is it better/easier to remove the tranny or engine? Also, any tips or how to's? Thanks in advance
Old Feb 3, 2013 | 03:08 PM
Mordgier's Avatar
How bad is the leak?
If it's minor - I'd not touch it. Also make absolutely sure it's not the valve covers leaking down the back.
If you have an automatic, I'd replace the flex plate while down there. Obviously if it's stick - the clutch.
If you have not done the timing belt yet I'd pull the engine and do everything that way. If you have, I'd drop the trans.
Old Feb 3, 2013 | 03:45 PM
The valve covers are leaking too. It's also due for t belt.
Old Feb 3, 2013 | 04:53 PM
vital22re's Avatar
totally a bro
Leaks start from the top down. Start with timing belt, tune up and valve cover gaskets. Grab some brake cleaner or pressure washer and clean up the oil dirty area . Then monitor for leaks.
If you want to do it all at once, yank the motor and reseal the motor while its on a stand. Of just pull the transmission and swap the rear main.
Old Feb 3, 2013 | 04:56 PM
The weird thing is it leaks while not running. It sits at work all day, and there are spots under it. I can see it coming outta the front of the bellhousing too.
Old Feb 3, 2013 | 05:24 PM
Mordgier's Avatar
If you want to pull the engine, use this thread:
http://www.toyota-4runner.org/3rd-ge...e-removal.html
Old Feb 3, 2013 | 05:45 PM
vital22re's Avatar
totally a bro
Clean the crap out of the engine bay, then watch to see where it comes from. Could be valve covers leaking.
Old Feb 3, 2013 | 05:53 PM
Thanks fellas
Flying91
45
Apr 11, 2024 04:39 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Avenged
Jul 9, 2015 07:55 AM
toyoda8488
Jul 5, 2015 10:18 PM
