Battery Cable Extension
Old Jan 4, 2007 | 03:39 PM
4runner46's Avatar
I just bought a new battery for my 97 4runner, but it is a little different from the old one. It is shorter, so the battery holder does not clamp the battery on its own. For this I added wooden spacers on top of the battery, but there is another problem: the way the terminals are placed, my battery cables are too short to reach them. This may be partly because of the body lift, but the old battery fit fine. Is there an easy way to extend the battery cable or terminal so that they reach?
Old Jan 4, 2007 | 03:45 PM
Bob_98SR5's Avatar
are the battery terminals in the same spots as the previous battery? also, you can always put a piece of wood *under* the battery instead of on top as spacers.
bob
Old Jan 4, 2007 | 03:57 PM
rocket's Avatar
Sounds like now would be a good time to upgrade your battery cable(s) to heavier gauge wire.
https://www.yotatech.com/forums/f131/big-3-wire-upgrade-95850/
Old Jan 5, 2007 | 05:52 AM
gpcollen1's Avatar
You can buy battery cable extenders for an interim solution until you plan out the wiring swap / upgrade.
Old Jan 5, 2007 | 08:43 PM
Elton's Avatar
i had to buy a 4'' battery cable when i got a battery for free its been like that for years and hasint been a problem there bolted togother and then wraped with lots of black tape
Old Jan 5, 2007 | 08:57 PM
4runner46's Avatar
Thanks for the help. I wired in an extension and it works fine. I might look into upgrading the wires down the road.
Old Sep 19, 2011 | 01:58 AM
jbuck07's Avatar
well, i know its been 4 yrs since your last post; but...... where did you get the extenders from? i ran into the same problem on mine.
Bourbonblues
Dec 15, 2017 05:43 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Armstrong486
Sep 19, 2015 12:37 AM
toyotafreak98
Sep 10, 2015 02:57 PM
matthew138
Sep 3, 2015 08:21 AM
