PROBLEM: Wire Set Install
Old Jan 23, 2007 | 05:04 PM
jebus's Avatar
Well I was installing some new spark plugs and a new wire set for a 98 4runner V6 and I forgot where each wire goes. I have a number 1, 3, and 5 cylinder wires for the 5vz and I don't know where each wire goes. Can anyone help? I feel stupid forgetting where each wire was suppose to go.
Top Left goes to which cylinder to the right
Middle Left goes to which cylinder to the right
Bottom Left goes to which cylinder to the right
Thanks.
Old Jan 23, 2007 | 06:03 PM
aowRS's Avatar
From my experience, the wires all have a specific length. That is, once you snap them into the plastic holders (from passenger to driver side), they can really only lead to the correct plug. If you attach them properly across the top of the timing belt cover, you can loosely extend them along the driver's side bank. It should make send then.
Andreas
Old Jan 23, 2007 | 06:30 PM
gpcollen1's Avatar
Maybe you didnt open the wires yet but it should be readily apparent as just mentioned.
Old Jan 23, 2007 | 07:49 PM
Mason Dixon's Avatar
just for reference for anybody that pulls this up in a search, take a digital pic before you change the wires as was stated in another writeup, to make sure you can backtrack just in case
Old Jan 23, 2007 | 07:53 PM
Elton's Avatar
i have the ngks on mine if no one has a answer soon i can look at mine
Old Jan 23, 2007 | 07:56 PM
jebus's Avatar
Took me a while, but I got it all working. Thanks for all the help.
Old Jan 23, 2007 | 08:59 PM
Elton's Avatar
for any one else that has a hard time heres how it go's its very easy the fireing order on the 3.4L is
5 --> 6
3 --> 4
1 --> 2
pretty much the wires go straight across from each other
Old Jan 24, 2007 | 09:18 AM
jebus's Avatar
5 --> 6
3 --> 4
1 --> 2
Mines wired different from that. I got
5 -- 2
3 -- 6
1 -- 4
And it seems to run fine with that...something wrong here?
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
bryan34w
Jul 6, 2015 05:53 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
