need help deciding what size tires would fit
Old Jan 16, 2007 | 10:36 AM
atl4runner's Avatar
i have a 2001 runner and i just installed a 3' toytec coil spacer lift and i want to know what size 33 i can fit under it..i know most of yall run 285s and ive searched for them but it looks like you can only fit 16s on 285s? id really like to run a 15 inch wheel aswell but i dont really know what width would be good?? i dontw ant it to look like my tires are too wide ya know? can someone help me out?
Old Jan 16, 2007 | 11:03 AM
04 Rocko Taco's Avatar
you may have trouble fitting 15" wheels. Did your runner come with 16" wheels? If you have VSC, you CANNOT run 15's. If you can, I would say a 33X12.50 would fit with minor rubbing, but unless you need it, I would say just stay with the 33X10.50. You should always get the smallest tire you need.
Old Jan 16, 2007 | 11:31 AM
Also - just noticed your name ATL 4runner. You in the ATL area?
Old Jan 16, 2007 | 05:23 PM
CLEANSR5's Avatar
yea i had problems with 15's, so check that out before you even consider it.
Old Jan 16, 2007 | 07:03 PM
Elton's Avatar
285s should fit
Old Jan 16, 2007 | 07:35 PM
wjwerdna's Avatar
http://www.discounttire.com/dtcs/infoTireMath.dos
here, play with this tire comparator thingy...
just put 285-75-16 into the first box, and then put known versions of 15" tires in the second part, then compare to see what ones have the same decimal widths and overall diameter
for example ...
285-75-16 width = 11.22" diameter = 32.83
285-80-15 width = 11.22" diameter = 32.95
i just don't know if it is a real size tire
Old Jan 17, 2007 | 12:36 PM
atl4runner's Avatar
yeah it came with the flower bloom 16' wheels and im pretty sure it came with VSC so basically i should rule out all 33 inch tires and i have to run metrics like 285s? yeah i live outside of atlanta in the suburbs..specifically alpharetta if you know where that is
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
Yotoder865
Jul 9, 2015 07:51 PM
