Disable DRLs...Which wire?
Old Jan 16, 2007 | 01:11 PM
proscllc's Avatar
My 2000 Tacoma doesn't seem to correspond to the TSB or other threads I can find. My DRL module is under my dash above the gas pedal (at least I think that's it :confused: ). The connector (D8) has these wires coming in...http://prosgetpaid.com/tacodrl.html
So is Pin #2 (the one I'm supposed to cut) the black w/orange stripe? or the purple w/yellow stripe?
I've read that a 2000 4Runner had a black w/yellow stripe. I would have thought the 2000 Tacoma would have been the same, but....
Help?
Old Jan 16, 2007 | 01:43 PM
OSU4Runner's Avatar
Ya....The DRL module is in the same spot on 3rd gen 4runners......I cut pin #2 and it worked fine....but mine wasn't the same color as it said in the tech write up.....Just cut it a few inches back from the connector, that way if it doesn't work, you can splice it back together.
Old Jan 16, 2007 | 02:35 PM
proscllc's Avatar
Okay, how do I know which one is the #2 pin. They are not labeled and assuming I just start counting from the outside in, I'll do it if I know which row to concentrate on.
Old Jan 16, 2007 | 02:43 PM
OSU4Runner's Avatar
There should be 2 larger pins on either the left or right side of the connector depending on how you look at it. Cut the inner wire.....here are some pics from the tech section.
https://www.yotatech.com/forums/showthread.php?t=75269
Old Oct 21, 2007 | 10:54 AM
02Surf SSR-X 4xSport's Avatar
Disconnect PIN 2 (Black/Orange stripe) wire of D8.
Old Oct 21, 2007 | 10:55 AM
OSU4Runner's Avatar
Wow......old thread
Old Oct 21, 2007 | 06:56 PM
Rock Slide's Avatar
Holy crap...I didn't realize how many DRL threads we had
80Truck
Oct 12, 2025 07:25 PM
theking11863
Mar 19, 2016 09:36 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
