oops... I broke a fan pulley stud
Old Jan 10, 2007 | 12:21 PM
JHRRLD's Avatar
Unhappy oops... I broke a fan pulley stud
A couple of months ago I pulled my stock clutch fan to install a permacool 18" fan. While I was tightening the nuts with some washers as spacers I accidently over torqued one of the nuts and it broke the stud. I went the local home depot and picked up a new nut of the same thread pitch and luckily had enough threads left for it to hang on (has been good since I did this anyways). You can kind of see what I'm talking about in this blurry pic:
Also when I wash my car the belts will squeal for about 15 seconds when I first start it up or drive out. I assume this is happening now because the efan doesn't kick on when it is first started or while running in an auto car wash like the clutch fan would be keeping water off the belts.
This weekend I will be installing the TuRD SC and URD fuel upgrade goodies and at the same time I'm going to be replacing all the belts. I figured I would also see about replacing the stud I broke. Couple of questions:
1.Is this a simple fix? IE can I go to toyota and just pickup the stud and nut or is it a buy the whole thing deal and not really worth me messing with?
2. Am I correct in my assumption about why the belts would squeal? Would replacing them help at all?
Any and all input welcome. Thanks guys/gals
Old Jan 10, 2007 | 01:04 PM
mt_goat's Avatar
I replaced all my studs with shorter bolts after I removed the fan. That way you don't need a stack of washers to fill the gap.
On the squealing, check the belt tension. The fan or lack there of has nothing to do with it IMHO.
Old Jan 10, 2007 | 01:30 PM
JHRRLD's Avatar
Originally Posted by mt_goat
I replaced all my studs with shorter bolts after I removed the fan. That way you don't need a stack of washers to fill the gap..
Dale,
Does that pulley just slide off the studs when you remove the belts? Where is a good place to get shorter studs and do they need to be pressed in or anything?
Go pokes! beak KU!
Old Jan 10, 2007 | 02:48 PM
mt_goat's Avatar
Originally Posted by JHRRLD
Dale,
Go pokes! beak KU!
Yep, just slides off after you remove the nuts too of course. Ace hardware has metric bolts that size. Studs are just threaded into place, you may have to jam double nuts on them to get a grip on them though. That could be a problem with your broken one.
Yeah hope we can finally win a game up there for a change, should be a good game. Go Cowboys!
runnermedic
13
Sep 21, 2015 05:20 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
Corvoid
Sep 14, 2015 10:10 AM
128keaton
Sep 3, 2015 05:09 PM
Aaron Logan
Sep 3, 2015 08:08 AM
