? for those with 4.30 gears and 33s
Old Mar 8, 2008 | 04:05 PM
hektikwon's Avatar
Just wanted to know if anyone with 4.30 stock gears noticed a big drop in gas mileage or power when they went to 33s or 285/75? Oh I guess I should say auto 3.4 also.
Old Mar 8, 2008 | 07:24 PM
Nate08's Avatar
I don't have 430s I got 410 and I lost 3 MPG. 430's might lose 1.5 (guessing).
Old Mar 8, 2008 | 08:04 PM
BLKNBLU's Avatar
I'll bet you didn't. Your truck is actually travelling further with every tire rotation than it used to, and your odometer isn't accounting for it. I don't know how to make the conversion but I bet someone on here does. (or has a link)
Old Mar 8, 2008 | 08:05 PM
4Runner202020's Avatar
i have 4.30 and didn't notice a difference. and i got 305's . just wider. lol more drag.
Old Mar 8, 2008 | 11:09 PM
hektikwon's Avatar
I guess the 33s wont cause me to have to regear. Thanx for the input
Old May 12, 2008 | 01:15 PM
Djlarroc's Avatar
*Revive*
So what would be a size to cause a regear? 315s? I drove a manual '00 Runner the other day, I think it had 4:10s. First gear seemed short. REAL SHORT.
Old May 12, 2008 | 01:59 PM
i have 35's now up from the 33's in my previous post in this thread and 4.3's and i dont think i'll be re-gearing... i get 15 city and 18 highway and pull hills in 5th still going 75 on I-25. 4.10 will be worse though...
Old May 12, 2008 | 09:43 PM
Albuquerque Jim's Avatar
I have nearly identical results.
Old May 12, 2008 | 09:57 PM
BajaRunner's Avatar
4.30 gears, 35s, I would say I get 15-17 city, 18-20 highway...I have to use a GPS to figure distances, the odometer reads a little off.
I drive like a grandma on acid so I'm usually crawling at a snails pace as I watch the grass grow beneath me.
Old May 12, 2008 | 10:06 PM
Jdizzydub's Avatar
...funny, I'm not quite sure what gears I'm running..anyone wanna help me figure this one out?? I've got a 97sr5 4x4 auto 3.4 and i haven't changed the gears.
I mean is this info related to the engine size, model, etc??
Thanks
Old May 12, 2008 | 11:18 PM
crolison's Avatar
Originally Posted by Djlarroc
*Revive*
try 4.56 and 1st gear, really short. I have to be in third at 3500rpm to hit 60
Old May 13, 2008 | 08:01 AM
Djlarroc's Avatar
LOL! I can see why.
Thanks
It doesn't look like you have the e-locker which points to 4.10s. Although you do have the auto... Would that be 4.30? Did Toyota make an adjustment for autos? Hmmm...maybe not because of the 3.4's torque. I'm thinking you have the 4.10s.
How does it drive on your bigger tires?
Old May 14, 2008 | 11:22 AM
Jdizzydub's Avatar
So to regear properly i should go down to 4.30?
Turding around town it's great, on the freeway and hills it kills. I've pretty much lost passing speed unless od is off and it rides at 3000, it pulls good in that range.
Old May 14, 2008 | 07:23 PM
4.30's are still technically a little high for 35's. 4.56's would put it back to stock and 4.88's would be a little extra low end power at the sacrifice of higher rpms at highway speeds.
If I had it to do over again I would have re geared to 4.88's...live and learn.
Old May 14, 2008 | 07:27 PM
apalmer1's Avatar
I run 33x1250's with 4.10's. I notice probably 1mpg difference in gas mileage which is normal for the extra drag from 10.5's to 12.5's. there isnt that much of a power difference, i used to drive my truck over Santiam pass here in Oregon every single weekend on the 33's-its one long steep uphill, and i never really had any power issues. I actually fried my diff and regeared it to 4.10 again, i kinda wish i had gone with 4.56 but its certainly not necessary and far more expensive.
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Cabell
Jul 24, 2015 12:14 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
