SS lift... help me choose
Old 03-01-2008, 06:41 PM
Guest
Guest
Posts: n/a
ok so i blew out the shocks in my 97 4runner 5spd 4wd. you all know ive been looking around for my best option and changing my mind about 500 times. but I finnally settled on a Sonoran Lift either the #1 or 7. Im one of those people that like the best but the cost was kinda swaying me. Anyways so Im gonna be running 265/75r16 mostly due to this is a DD and mabey twice a month sees a trail. Ill be running Geolandar ATs.
My runner has stock bumpers but I plan on adding sliders soon and I already have a class 3hitch. I also have about 200-300lbs in the rear almost all the time as well as towing a small motorcycle trailer about 400 miles a month.
I know steve would be the best to ask but I want to hear your inputs as well.
Thanks for the input!
Old 03-01-2008, 07:31 PM
Taro's Avatar
The 7 sits level but if your carrying all that weight all the time and towing it might sit low in the back. I'd go with the System 1.
Old 03-01-2008, 08:12 PM
Guest
Guest
Posts: n/a
I was thinking the same might as well get the system 1 and if I go system 1 can I run 305/70r16 with mild trimming? or is 285/75r16 my max? without a whole buch of hammering and hacking? I meen really the only think between the 285 and 305 is width. mabey 1 in wheel spacers?
Old 03-01-2008, 08:32 PM
4Runner202020's Avatar
i got OME 883's with the toytec top plate spacer and 890's with a 1 1/2 coil spacer in the rear no body lift and am runnin 305's no problem. 315's fit but i didn't wanna have to re gear so soon... but then again i got custom front and rear bumpers and hi clearence fiberglass fenders... just a thought.
Old 03-02-2008, 12:11 PM
Nate08's Avatar
System 7 will also ride more harsh than system 1.
Old 03-02-2008, 12:59 PM
rdang's Avatar
With all the research I did prior to purchasing my suspension lift, the SS 1.1 was the only lift kit that I could find that no one was bad mouthing, every other kit I saw had some sort of negative feedback.
If you want the best, it's going to cost you.
Old 03-04-2008, 04:39 PM
Guest
Guest
Posts: n/a
Well I got a steal on some 245/75r16's Goodyear MTR's like new 5 for 500 so I couldnt pass that up. And I ordered my SS 7.2 lift as well. Ill post pictures when I install it hopefully the 18th or 19th of this month. And hopefully after that building my sliders and prerunner bumpers (not a fan of the ARB style bumpers). Thanks all for the help
Old 04-02-2008, 12:24 PM
mayfield's Avatar
you have a transmission/steering cooler installed?
Old 04-02-2008, 12:26 PM
rdang's Avatar
No... should I?
Old 04-02-2008, 12:49 PM
mpavolka's Avatar
No... should I?
I don't know why this thread went to this but if your 4Runner is an automatic there is a tranny cooler in the radiator.
Old 04-02-2008, 12:52 PM
mpavolka's Avatar
I have never owned or ridden in a truck with Cruiser Coils but I have the rear system #7.2 with the exception of OME 891's and I think it rides very well, better than stock or Downey springs I have owned. I can only imagine that the OME 890's would ride better, however I haul and tow a lot of weight.
Old 04-02-2008, 12:54 PM
mayfield's Avatar
I should have sent him a private message asking him the type of transmissions he had. I purchased a SS 2.1 kit today, and will run 305/70/16 MTR's. i just wanted to know if fluid temps increased requiring him to install or upgrade cooling. thats all
Old 04-02-2008, 01:00 PM
rdang's Avatar
Hahaha - sorry mayfield, thought you were taking a shot.
I have an automatic - I wasn't aware that I need any additional cooling for my 33's. Most guys on here recommend the transmission cooler and break upgrades if you go with a 35" tire, not a 33 so I never bothered.
Whether the fluid temps increased or not, I don't know - I would imagine that they did a bit, but I've driven an hour straight on the highway and no problems. Hope that helps.
Old 04-02-2008, 01:30 PM
mayfield's Avatar
haha, no problem
Okay, i read the same thing on the forums that a cooler was required with 35
" ..I just wanted to check with you to see if you were experiencing any problems. this is good news for me! thanks for your post
the1998sr5
27
11-17-2015 09:30 AM
thzpcs
10-03-2015 07:39 AM
PureTacoma_Tundra
PureTacoma_Tundra
09-24-2015 12:14 PM
sphealy
09-03-2015 07:55 PM
Odin
08-30-2015 11:44 AM
Quick Reply: SS lift... help me choose
