Popping sound around front passenger side wheel
Old Mar 6, 2008 | 05:44 PM
Quattro15's Avatar
When I turn hard or hit a bump at speed there is a popping sound that comes from my passenger front tire area. I've looked and don't see anything loose or out of place. The pop only happens once, like something is settling into position or something like that.
What could be making this sound?
Old Mar 6, 2008 | 06:15 PM
904_runner's Avatar
There is supposed to be little plastic caps over some bolts on the bottom near the frame near the control arms, they fell off. Sorry i don't know what the area is called but Look at the other side to see what im talking about! Go buy some new ones from toyota if it bugs you. but they break easy!
Old Mar 6, 2008 | 06:16 PM
loacyota's Avatar
What kind of vehicle? 2wd or 4wd ? what year?
Old Mar 7, 2008 | 03:24 AM
Quattro15's Avatar
1999 Extended Cab 4WD SR5 TRD
Old Mar 7, 2008 | 05:48 AM
BajaRunner's Avatar
It could be a number of things. I would just go ahead and tighten the three top nuts on the strut, the bottom bolt on the shock, and the sway bar endlinks.
If there still is a sound, you may want to check to see if your ball joints are ok.
Most likely its something to do with your shock/spring. Have you done any suspension modifications?
Old Mar 7, 2008 | 06:22 AM
97ltd4x4's Avatar
Possibly sway bar buishings,and/or endlink buishings.Especially if you are getting noise while going strait and while turning with bumps/dips....If the sway bar buishings and endlinks are ok,and you are hearing noise while turning and hitting bumps like say a drainage curb where the road meets a driveway in a subdivision I would start thinking balljoints....This is all assuming everything is tight in front end from any modifications.
Old Mar 7, 2008 | 11:53 AM
Quattro15's Avatar
No suspension mods...but I've hit some nasty bumps at speed while off-road.
Old Mar 7, 2008 | 12:09 PM
cackalak han's Avatar
I'm betting on broken endlinks. Those things have the strength of a popsicle stick.
Old Mar 7, 2008 | 12:38 PM
Quattro15's Avatar
Endlinks are good....just went out and checked them. I guess I'll tighten everything down tomorrow and see what happens.
How much are ball joints going for?? I think something like 60 bucks? And can I install it by myself? Seems like if I jack the suspension up I could do it.....this is if the other remedies don't work out mind you.
Thanks for the help! This forum has saved me some major cash on repairs at the stealership!!
Thanks again!
Old Mar 9, 2008 | 07:00 AM
Quattro15's Avatar
So I just tried to tighten everything and there was nothing loose. The endlink on both sides of my truck moves around, side to side, when I try to tighten the bolts on them....I don't know if this is what they are supposed to do or not?
What else could it be? Ball joints?
Thanks!
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
coryc85
Jul 7, 2015 04:05 AM
colinmil
Jul 6, 2015 04:03 PM
zd92655
Jul 5, 2015 04:25 PM
