Bad Injector
Old Mar 13, 2008 | 09:06 PM
NwRunner's Avatar
Bad Injector
So i keep getting a Cylinder2 misfire, and after replacing the cap, rotor, plugs, and plug wires im pretty much down to a bad injector. Im going to pull the Injector and clean it tomorow, but if the problem persists and i need to replace it, should i just replace them all, or is that unnecisary?
Also, anyone have any thoughts on something besides an injector? ive already put $125 in this problem with no result, dumping more in without result is doesnt sound like a good idea. And i know, "take it to a mechanic" but im not paying $80 to hook it up to a machine that will tell them to charge me $300 to repair a small problem.
Old Mar 13, 2008 | 09:12 PM
toytech76's Avatar
You need to take it to someone who can tell you what is wrong. Throwing money and parts at it hoping it will fix it is not the solution. You will be time and money ahead
Old Mar 13, 2008 | 09:21 PM
NwRunner's Avatar
my neighbors are all halfway honda mechanics, injector was their top choice, but they dont have the equipment to make a proper diagnosis. I guess i have to face facts that my car might actually have a....a... problem
Old Mar 13, 2008 | 09:23 PM
Dare44's Avatar
its a toyota it cant have a...a... i cant even bring myself to say it
Old Mar 14, 2008 | 05:22 AM
edzo's Avatar
there are no problems with toyotas, only solutions
Old Mar 14, 2008 | 06:36 AM
Ohio4R's Avatar
Did you replace the coils? Im pretty sure you dont have a cap and rotor style system. What spark plugs did you get? Injectors rarely go bad.
And your neighbors being honda mechanics... those are hondas they have problems toyotas are different.
Old Mar 14, 2008 | 07:11 AM
97ltd4x4's Avatar
How is the compression/leakdown on that cylinder?What does the plug look like?Can you introduce carb cleaner in a vacuum hose with the engine running,does it smooth out?
You only need to replace that one injector and fuel rail washers(line-rail),If it went bad,It didn't do so by being clogged,you would have all/or most go bad if that was the case.Actually your fuel pump would go before the injectors would clog.
If it is a bad injector it probably its probably wet electrically bad.
Old Mar 14, 2008 | 07:14 AM
NwRunner's Avatar
being as i replaced the cap and rotor myself, i am pretty sure my motor uses that system... Im not completley incompitent when it comes to cars, but my knowledge isnt that great. I might take it to a friend who is a UPS mechanic, and i will have him check coils also.
Old Mar 14, 2008 | 07:16 AM
NwRunner's Avatar
that is what i needed to know, thank you
Old Mar 14, 2008 | 07:20 AM
SEAIRESCUE's Avatar
A white looking plug compared to the others is a sign of a lean injector. I had one die on me in a 22RE engine. It had about 250K miles. I changed them all and my power came back and the plugs started looking normal. You can send them to Dr. Injector in Washington State or some other tester/fixer. New gaskets is mandatory and each injector has several. See the dealer for the new seals.
Other problem could be compression. If that is the case, check valve adjustments first. Most ohv engines suffer from valve retraction into the head as the valves get beaten into the seats over time.
My $0.02
Old Mar 14, 2008 | 06:45 PM
NwRunner's Avatar
well i finally made and appointment with a mechanic. I swapped injectors with cyl3 and still have cyl2 misfire, So i now know its mechanical, probably a valve im guessing.
Old Mar 15, 2008 | 06:18 AM
Adam F's Avatar
I'm guessing he has a 3rz 4 cylinder which had a distributor
Old Mar 16, 2008 | 01:31 AM
NwRunner's Avatar
You would be correct
Old Mar 26, 2008 | 10:58 PM
thmpr's Avatar
Why didnt you run an ohm test on the injectors?
Old Mar 28, 2008 | 03:34 PM
3w41d's Avatar
Hi. i just got the same problem fixed on my 2000. one of the exhaust valves on the #1 cylinder was burnt from the previous owner never replacing the valve shims.
anyway, i would recommend doing the compression test and seeing whats up, if it comes back at zero like mine did, have your mechanic pull off the valve cover and replace the shims. if that doesn't do it, have them remove the head and do the valve and hope the valve seat isn't completely f***ed
hope this helps
Dylan
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
RatOmeter
Oct 22, 2015 03:17 PM
pyramid
Jul 29, 2015 06:53 AM
