Parking brake light when I shift?
Old Mar 6, 2008 | 08:06 AM
NwRunner's Avatar
I have a 5speed 4cyl Runner and i have noticed that usually everytime i shift, my Parking Brake light comes on, then goes off a short time after. Now i have made sure that the arm isnt jumping, because i taped it down and im still having the same problem. Anyone one having the same problem or have an answer? It usually happens in the lower gears and i do smooth shifts, not jumpy ones that would warrant something like that.
Old Mar 6, 2008 | 08:30 AM
97ltd4x4's Avatar
Brake fluid is low in master cylinder......causing float to drop during shifting.
top off fluid,check brakes for wear.....It might be time for some new pads....
Old Mar 6, 2008 | 08:34 AM
NwRunner's Avatar
thanks for the quick response, ill try that tonight.
Old Mar 6, 2008 | 08:56 AM
zlathim's Avatar
Good advice.
Old Mar 6, 2008 | 09:45 AM
crolison's Avatar
Its most likely brake fluid low like stated above. I had this happen after taking apart my rear axle and bleeding the brakes when i put it all back together.
Old Mar 6, 2008 | 09:59 AM
dirtoyboy's Avatar
maybe the parking brake is just out of adjustment?
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
