trying to ID my gear ratio
So i was trying to decode my rear gear 1997 4runner. My vin number starts with JT but my gear info falls under the 4T gear info. Whats up with that. According to the 4T list i have a : A03A......A=7.5 03=4.10 A= 2 pinion
I cat find anything to figure it out under the jt listing..I found the info on
http://www.toyota.offroad.com/toyota....jsp?id=274535
Any ideas?
Any ideas?
Not sure if that table works on the later model diffs, but you can always spin a tire and count driveshaft revs:
http://www.4crawler.com/4x4/4R_TechI...oDetermination
Ok , if we dont get washed off the map tonight it is supposed to storm tonight. ill try it in the morning. I need to find out cause i found a whole E- locker rear end drum to drum. It would be really nice to just swap out and wire it up and not have to worry about setting up gears for a change. Thanks
Without saying anything difinitively, I heard that if your truck was an auto and came with the E-locker and had the 265/70/16s, it had 4.30s. I am going to verify this tomorrow if we don't get rained on either. Without the E-locker, it was 4.10s.
You can't go based on the 4T list. That is only for vehicles built in California. All (I think, correct me if im wrong) 3rd gens were built in Japan, thus the JT VIN.
IIRC A03A should be a 3.91 diff ratio.
Try this link: http://www.vibratesoftware.com/html_...les.htm#Tacoma
Well, I tried it morning.It turns 4 times and a little bit, maybe close to 3 inches more on the 4th turn. I think it was close to 1/3 of a turn than half a turn. 1/3 would mean i have 4.10. 1/2 of a turn would be 4.30 I would feel better to just go in it and count it up to be exact
This is the source I used: http://www.brian894x4.com/Gearratiosanddiffs.html
This table tells me I have stock 4.56 gears
if you turned wheel 2 times to get 4.10 or 4.30
then if you turn wheel 10 times you will get even 20.5 turns
.......if you turn wheel 20 times you will get even 41 turns of DS, but thats a lot of counting
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
