Octane rating
Old Mar 9, 2008 | 07:14 AM
fasthorse67's Avatar
Octane rating
Does a 2002 4Runner require 91 octane, or is 87 fine. I looked at the owners manual but it says that 87 is required with some other rating of 91. So I couldn't determine which it's supposed to use.
Old Mar 9, 2008 | 07:18 AM
CJM's Avatar
CJM
Yes, 87 is fine.
Old Mar 9, 2008 | 07:55 AM
cackalak han's Avatar
I use 85, which is considered regular up here (due to elevation). Whatever octane "regular" is, that is what you need to put in.
Old Mar 9, 2008 | 08:52 AM
sweet, thanks
Old Mar 9, 2008 | 09:17 AM
rdharper's Avatar
87.
This is an endless debate it seems. Truth is, all modern engines must run correctly on '87.
As to how well, my Ridge manual states 87. Further, they state you are wasting your money to use a higher octane. This is correct, and the frist manual I've ever owned that puts this fact in print.
Some like to believe they are "taking care of their baby" or some such comment.
Some have a problem with their EC setup, which seems to helped by higher octane.
Some mod their vehicles such that they think they must run higher octane.
Because of EC designs, the timing adjusts to correct for pre-ignition. There is actually more energy in lower octane fuel. If your vehicle works correctly, you lose no power, and have a lower cost per mile.
Period.
Old Mar 9, 2008 | 09:30 AM
Some vehicles must use high octane, I just wanted to make sure the 4Runner was not one of them. My Camaro needs high octane, 10.5 to 1 compression, runs horible on 87, it contiues to run/knock after you shut it off. The supercharged Frontier I just sold needed it, if I used 87 in it, it would retard the timing and dump the boost, resulting in no power and very bad mileage. I understand that every vehicle will "run" on 87 but if it's not designed to it will lose power and the mileage will suffer.
Old Mar 9, 2008 | 11:11 PM
stormin94's Avatar
Is that any cheaper than 87 in other places?
Old Mar 12, 2008 | 11:03 AM
SteveS's Avatar
Period.
Octane has nothing to do with the energy in gasoline. It controls the rate of burn for the fuel. Higher octane burns slower than low octane, this gives longer expansion during combustion.
Old Mar 12, 2008 | 11:28 AM
Seems like it. I was out in Reno a couple of days ago, and 87 was up around $3.30 or something like that. Here in UT, it's $2.90 for 85. The difference in Octane and location probably has a lot to do with the price difference.
Old Mar 12, 2008 | 12:20 PM
edzo's Avatar
octane doesn't have anything to do with the energy content...correct in a literal sense
BUT
in gasoline for automobiles, higher octane gas has less energy per liquid unit than lower octane gas
if your engine can run on 87, use it for better mileage
if you have higher compression engine which requires a higher octane to prevent detonation, use the higher octane stuff
the only benefit of higher octane on a taco or 4runner, is if you have done
engine modifications and are using high compression pistons, new ecu program, and radical cams, then you will get some performance out of higher octane gas. the fact you are running higher compression cancels out the energy loss of the higher octane fuel, so you end up faster from the engine mods and the fact it doesn't detonate
using high octane gas in an engine that doesn't require it, just lowers your mpg and empties your wallet
--->usually, but not always. in special high octane formulations that you cannot buy at the local gas 'n sip,
you may find high octane -and- high energy fuel. this is specially formulated and not available in stores.
read up
http://en.wikipedia.org/wiki/Octane_rating
Old Mar 12, 2008 | 12:26 PM
stormin94's Avatar
does having variable Valve Timing, and ignition timing give you any more power while running premium, than just a regular fuel injected engine?
BTW, both engines normally run on regular.
Old Mar 12, 2008 | 12:37 PM
rdharper's Avatar
The point is, octane modifiers occupy volume. Which translates to less energy per unit volume. 87 octane has more energy per unit volume than 93, for that reason.
Of course it doesn't do you any good if you can't tap that energy. Pure gas would have the lowest octane, and the highest energy per unit volume.
Capiche?
Old Mar 12, 2008 | 12:52 PM
edzo's Avatar
nope, no more power
it will if you have higher compression to go along with the fancy timing, but it isn't the gas giving the power, it is the fancy mods. the octane allows you to tweak the mods and compression without 'sploding to bits
Old Mar 12, 2008 | 12:58 PM
Id_Angler's Avatar
I have a 91 4Runner and it seems to prefer high octane fuel
Old Mar 12, 2008 | 01:04 PM
Matt16's Avatar
Higher octane gas CAN give you more power. If the explosion occurs too far before TDC, part of the energy from the explosion pushes the piston BACKWARDS. Most of the energy will still be exerted on the downstroke, so the engine will continue to turn over properly and produce some power, but not as much. High octane gas insures that it is the spark that ignites the fuel and not the compression.
As a result, your engine my "ping" under heavy throttle. If you were to test out a multitude of octane ratings, you would find that say, an 83 would give very little power, the 85 modest amount, 87 full power and no benefit from going to a 89 or 91 octane.
Old Mar 12, 2008 | 01:12 PM
rdharper's Avatar
VVT and ignition timing allows your engine to run correctly over a broader range of fuel and rpm's. In fact it allows the use of lower octane gas with the same compression ratio, all other things being equal. VVT also can give you more torque at lower rpm's
Old Mar 12, 2008 | 01:28 PM
colsoncj's Avatar
VVT allows most IC engines, depending on how it is applied, to run more efficiently (more mpg's) and produce slightly more power at a given RPM.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
Firefightersink15
Nov 23, 2015 10:32 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Boomer8404
Sep 17, 2015 07:59 AM
