Got my estimate for 4.56's.
Old Mar 6, 2008 | 09:59 AM
Nate08's Avatar
For Yukon gears with master kits and all that junk front and rear installed, it is $1800. Is that a good deal or no? I'm not gonna let myself get raped on this.
Old Mar 6, 2008 | 10:12 AM
dirtoyboy's Avatar
just buy some used toyota gears.....you can pick up already built diffs and save your self about 1300 bucks.... you could get 2 diffs built with e-lockers for way cheaper than that
Old Mar 6, 2008 | 11:57 AM
mr_schuster's Avatar
$1800 sounds really high to me. I have Yukon 4.56's and paid just over $300 for front and rear combined from Randy's Ring and Pinion. They also offer used gears as well. Can't remember any warranty with the used ones though. I don't see any reason to purchase a master kit with bearings. If your bearings are good then re-use them, how often do they go bad?
My opinion, buy the gears (new or used), shim kit and new pinion seals and carry them down to a machine shop if you don't feel comfortable with the install. Or buy used carriers with gears already installed.
Old Mar 6, 2008 | 12:23 PM
Vermejo's Avatar
Randy's quoted the following:
1800 even will get you exactly what you stated above + ARB RD-90 front locker and a ARB compressor #ARBRDCK. Mind you this is 4:88.
ARBRD90 $725.00 1 $725.00YG T7.5R-488R $190.80 1 $190.80YG TV6-488 $208.46 1 $208.46YK TACOMA-LOC $218.23 1 $218.23ARBRDCK $198.00 1 $198.00YY T35040 $40.00 1 $40.00TOY20001 $3.50 1 $3.50TOY18001 $3.00 1 $3.00YK T7.5-REV $213.34 1 $213.34----------------------------------------------Estimated Subtotal: $1,800.30
Old Mar 6, 2008 | 12:34 PM
Rock Slide's Avatar
Yeah, $1800 total is high for just gears & labor. On average in my area, frt and rr gears only + install runs about $1300.
Why Yukons though...I prefer Precision gears.
Old Mar 6, 2008 | 01:02 PM
Slednutjetskier's Avatar
Where would you get used complete diffs dirtoyboy??
PM with answer if you have a good spot!
Old Mar 6, 2008 | 01:44 PM
phildelfino's Avatar
Anybody out west got a good spot for used 3rd members? My 3.slo needs help, plus I want 33" tires insted of the 30" I got now. With an auto tranny, should I just go right to 5.29's?
Old Mar 6, 2008 | 02:14 PM
Nate08's Avatar
Yukon is what he suggested. It is a local OffRoad store. I've heard good things about them. He said that was probably the best they carried.
Old Mar 6, 2008 | 03:22 PM
jjrgr21's Avatar
well we will need to know about the MPG's after you get gears, and rpm's.
Old Mar 6, 2008 | 03:35 PM
socalsvr's Avatar
Pro Gear, here in San Diego is a good source for 3rd members.
http://www.progeardifferentials.com/
Old Mar 6, 2008 | 03:38 PM
CASTAIC 4RUNNER's Avatar
ive heard percision is way better ...and yukon hums your diffs
Old Mar 6, 2008 | 03:59 PM
4runnin2's Avatar
At the offroad shop I work at we do alot of gear installs. We sell alot of Different gears also Precision,Yukon,U.S gear to name a few. The reason they howl, humm or break is improper instalation 98% of the time. I would recomend the precision (thats what I run). But we do sell about 5 times more Yukon because of the price.
We charge $200 an axle or diff. for labor so your estimate sounds pretty high. maybe because it is more of a PITA to get the front diff out than a live axle. But in my opinion doing a Toyota 8" is as about as easy as it gets except a full float 60. Kinda balances itself out.
You probably don't need a master kit either.
Old Mar 6, 2008 | 04:56 PM
AndYota's Avatar
Yep, seems a little high. I was quoted around $1200 for 5.71s front and rear by Zuk (http://www.gearinstalls.com). That price was if I supplied him with a non-4.88 rear diff and housing and shipped everything to him.
Old Mar 6, 2008 | 06:20 PM
Nate08's Avatar
How can I know if I need the master kit before jumping into the project?
matrad
Aug 26, 2024 08:21 AM
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
yourrealdad
Jul 21, 2015 11:13 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
