Can too much oil in the engine show a code ?
Old Nov 8, 2005 | 11:48 AM
pfbmgd's Avatar
Can too much oil in the engine show a code ?Iput about a 3/4 of a litre too much in the engine with my last oil change .After a long drive the check engine light appered .
Old Nov 8, 2005 | 06:24 PM
GSGALLANT's Avatar
Can't say much without knowing the code. Get it pulled by a nearby shop or by a friend with a OBDII scanner, then post it up here. Once you have the code, you can search it here and find the information you need. There is a posting on the site somewhere that lists all the codes and the associated error messages. Good luck.
Old Nov 8, 2005 | 07:08 PM
pfbmgd's Avatar
Thanks I`m looking for someone with the code reader .They are kind of xpensive to buy .
Old Nov 8, 2005 | 07:17 PM
SnoViking's Avatar
check out your local advanced auto or simlar store.. they have the free to use one
bigjstang
Jun 2, 2025 03:56 PM
msane99
Jul 11, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
ptb12
Jul 5, 2015 01:49 PM
