Toyota fuel filter
Old Nov 3, 2005 | 05:13 PM
miami_54's Avatar
Toyota fuel filter
would anyone happen to know where the fuel filter would be located on a 1984 Toyota Pickup, 4WD, 22R, manuel transmission. I just cant seem to locate it. Thanks
Old Nov 3, 2005 | 05:40 PM
Nic's Avatar
Nic
I do believe it is under the intake manifold on those trucks. Very hard to get to.
Old Nov 3, 2005 | 05:41 PM
yotaluver's Avatar
on a 22re you go in through the right front wheel well
JamesD's Avatar
If it is carb then it is near the top of the gas tank with a little bracket with two hoses on it. If it is FI then like he said, under the intake.
James
Old Nov 19, 2005 | 05:29 PM
Cyrix51's Avatar
yeah he's right... i just replaced the FF on my 85' more than likely urs will be right above the gas tank.. its kind of a pain to get to... mines was also carb. but carb or no carb i wld check there anyway... i spent a whole hour looking for it then finally found the little pain in the ass.. so check that area just to be on the safe side
Old Nov 20, 2005 | 05:18 AM
barkeywayne's Avatar
as said above, if it is carbureted, the filter is held in a spring clip above the frame rail next to the gas tank, on the passengers side. If my gas tank is very full I usually take a small pair of needle nose vise grips and pinch off the "tank" side of the line to prevent siphoning. These filters are a lot easier to change on the long bed/frame models, you've got more room to manuever.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
ptb12
Jul 5, 2015 01:49 PM
