Antenna - Where's the Fuse ?
Old Nov 7, 2005 | 01:19 PM
TRD 4RNR's Avatar
My antenna doesn't go down any longer, however the motor still runs. Which fuse do I need to pull in order to kill the motor?
1999 SR5
Thanks.
Mike
Old Nov 7, 2005 | 02:22 PM
Tofer's Avatar
Sponsor
if the motor still owrks then chances are the plastic part broke. you can get replacements for much cheaper then the stealership here http://www.antennamastsrus.com/Toyot...01996-2002.htm
Old Nov 7, 2005 | 10:52 PM
ORB's Avatar
ORB
Don't know about a fuse, but before I put in my taco antenna, there was a wire harness behind the fender liner. Separate it and it will stop the motor from running.
Old Nov 8, 2005 | 03:33 AM
habanero's Avatar
Yeah, 10mm bolts, just turn the tire til it's out of the way, start from the left, which is where the antenna motor is, follow the wire to the connection, mine was up near the top of the wheel well. Super easy to fix if you go that route, there's threads about it.
zombie_barbarossa
Oct 2, 2015 10:54 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
Ilovemountains
Sep 15, 2015 04:17 AM
