slop in drive shaft where it meets axle
Old 11-12-2005, 07:28 AM
dirtypuke's Avatar
i have a 98 4runner and its grinding when i drive down the road i have noticed that there is slop in the drive shaft where it meets the rear axle. can i replace the pinion bearing with normal hand tools or do i need special tools? is this a huge pain in the a** job? do i have to pull the half shafts?
Old 11-12-2005, 07:06 PM
seaflea's Avatar
To replace te rear pinion bearing you will need special tools.
It is a fair bit of work even for an experienced mechanic.
Have you checked the U-joint? Maybe that is what is bad.
Old 11-12-2005, 07:08 PM
4Crawler's Avatar
If it is not too far gone, try tightening the nut on the pinion shaft. Unbolt the sdriveshaft, unstake the nut, tighten the 30mm nut to ~90 ft.lbs. to take up any slack, restake the nut and put the shaft back on:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
I had to do that on my old rear diff several times.
Old 11-14-2005, 10:22 AM
dirtypuke's Avatar
well i decided to take it to the tranny shop, and i know the guy pretty well. he looked at it and sure enough the ring and pinion bearings were shot. i am just going to let him do it. he is charging me 175 labor and what ever the parts cost. i figured that didnt sound to bad. there goes putting the jaos skid plate on this month.
thanks for the imput
Old 11-14-2005, 11:08 AM
getitdone's Avatar
imput...hahahahaha
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: slop in drive shaft where it meets axle
