Need Help With Automatic Hubs!!!!
I have a 1989 toyota v6 4x4 with the ADD system in it. Right now, I have to replace my differential. My truck is mostly disassembled and all I need to do is remove the CV shafts... but in order to do that, I need to remove the hubs. SInce they are ADD hubs, they are different than the automatic ones... HOW do I remove these hubs? Need help desperately.
-Nathan
-Nathan
Use a hammer and screwdriver to get the brass cap off the flange, take off the axle bolt and washer, unscrew the nuts holding the add flange in place, use a brass bar and a hammer to get the cone washers loose, use two bolts in the available holes to get the flange off if it doesn't come by itself.
Truckwithoutaname
Oct 3, 2015 03:41 PM
Toys4parts
Sep 26, 2015 01:56 PM
