brakes going out or something help please!!!
Old Nov 3, 2005 | 06:43 PM
totalchaosyota92's Avatar
alright i put on a spindal today and when i fully crank the wheel left or right my breaks will go out..... pedal all the way to the ground!! then i ahve to pump them to get my breaks back wtf could it be!!!! thanx
travis
Old Nov 3, 2005 | 07:25 PM
do you not know what a spindal is bro?
Old Nov 3, 2005 | 08:18 PM
98_YOTA's Avatar
maybe a brake pad slipped out when you installed the spindle, and its not in the caliper properly, or its not making full contact on the rotor.
Old Nov 4, 2005 | 09:19 AM
WVpizzaguy's Avatar
Did you open up the brake lines when you were replacing the spindal?
Old Nov 4, 2005 | 02:39 PM
Flamedx4's Avatar
Here's another possibility - If the hub can move, like with loose bearings or races that didn't fit properly to the spindle, the rotor will move back and forth and force the pads apart, giving you no brakes and the pedal will go to the floor.
REcheck the bearing preload.
Old Nov 5, 2005 | 08:10 PM
Lt. Dan's Avatar
Talking
Subtle Flamedx4...real Subtle.....Good suggestion.
(Heh - heh.....)
Old Nov 6, 2005 | 11:30 AM
Flamedx4's Avatar
I once destroyed a spindle, the bearing failed and the race seized to the spindle. The price of a spindle was insane! I cleaned it up and on the advice of an old-timer, dressed the surface with emery cloth until I could get a new bearing on. The new bearing went about 6 months - apparently it wasn't pefectly centered on the spindle now (go figure.) Again, on the advice of the old timer, I put on a new bearing and left it just a hair loose. That bearing had about 100k on it last time I saw it. But if you didn't hit your brakes for a while, the first time you hit them the pedal would go down a bit - not enough to cause No brakes, but enough you'd notice. I got used to it and never gave it much thought. Only happened occasionally.
and I couldn't resist on the bold print thing...
Old Nov 6, 2005 | 03:59 PM
punkbek3886's Avatar
my neigbor whos a 70 yr old machinist who restores cars gave the the same advice, emery cloth and all, when one of my races froze on the spindle.
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
