Transmission and power steering cooler?
Old Nov 11, 2005 | 02:51 AM
grimpy's Avatar
I am thinking about getting a tranny and ps cooler... Did a search and couldn't come up with much regarding the ps cooler... Would it basically be the same thing as the tranny cooler since it uses ATF fluid?
For the tranny cooler, I was thinking the Hayden 678... Any idea what I should use for the ps cooler? Same thing?
tia
Darrin
Old Nov 11, 2005 | 06:30 AM
ebelen1's Avatar
Know nothing about a ps cooler but the Hayden model you wrote down is what I've read. I bought one but have yet to put it on. I'm expecting in the next week or so. It was like $60 shipped. Only doing it to extend the life of the tranny; no towing in my future.
BTW, I'm slowly putting on all the bolt-on stuff so I can justify a s/c down the road. I believe all the s/c guys have a tranny cooler.
Old Nov 11, 2005 | 12:16 PM
grimpy's Avatar
yeah bro... I think the $60 for added insurance is a good thing. Also want to get one for my ps since i am running larger tires and would rather be safe than sorry.
Old Nov 11, 2005 | 01:38 PM
vegaskurt's Avatar
never heard of a PS cooler, but I would bet a small hayden or trans cooler will do what you need as long as it can handle the pressure.
Old Nov 11, 2005 | 01:54 PM
MTL_4runner's Avatar
The cooler should never be put on the pressure side (over 1200 PSI!!!!).
You could put one on the return side but I have never seen overheating of PS on a 4runner.
Old Nov 11, 2005 | 03:11 PM
SoCal4Running's Avatar
I put one of these on my CUCV after I switched to 37's. Works great
Old Nov 11, 2005 | 03:55 PM
crappled's Avatar
get the an fittings if you go with ps
... just for looks lol...
as you'll have the stock tranny cooler, the new tranny cooler, AND the PS cooler.
and ya, low pressure side, and there is no temp sensor for the ps so you're good to go.
Old Nov 11, 2005 | 04:09 PM
rugerm44's Avatar
Summit racing sells the power steering cooler also jegs.Simple just put longer lines on the low press side.
Old Nov 11, 2005 | 07:05 PM
grimpy's Avatar
thanks for the heads up guys... I will look further more into this... I read that it is a good idea to get a ps cooler when upgrading to larger tires... Is it a waste since I only have 295/75/16? If so, I'll probably just do the tranny cooler.
Old Nov 11, 2005 | 08:10 PM
noahrexion's Avatar
IMO its a waste for almost all... I cannot think of any situation where one would need a PS cooler on a runner. Unless you like to drive in figure 8's or just sit ina parking lot and trun your wheel back and forth you really don't need one, even with larger tires.
Best best for your PS system is to keep it flushed/clean with some decent additive maybe for your rack seals. No cooler needed unless you plan to drift the beast
Old Nov 11, 2005 | 11:55 PM
grimpy's Avatar
thats great to hear... I guess I won't be doing the ps cooler.
Old Nov 12, 2005 | 12:02 AM
BajaRunner's Avatar
Where are you going to buy your tranny cooler? I wanted to get one myself.
That pressure line to the PS is frigging insane. I uhhh "accidently" cut through it with a sawzall and that was one painful and expensive mistake !! A new pressure line from Toyota is ~$500... Luckily there is a "hose shop" in town and he welded it back together for me.
Old Nov 12, 2005 | 02:23 AM
grimpy's Avatar
Damn in that case I am definately not touching the ps...
I am going to check around the local shops to see if they have it in stock and the prices... If all else fails, there is always eBay.
Old Nov 12, 2005 | 05:16 AM
FilthyRich's Avatar
www.sonoransteel.com
All the info on what Steve did to mount a ps cooler
terminator
Jul 27, 2015 07:13 PM
keithporter83
Jul 24, 2015 07:37 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
jon.r
Jul 11, 2015 03:34 PM
Snort
Jul 9, 2015 03:58 PM
