First parts to break in IFS ?
Old Nov 7, 2005 | 03:10 AM
ThomasJ's Avatar
I did a search and did not really find an answer. What are the first parts to break from off road abuse on the IFS with ADD? CV's, hubs, differential, inner axles, etc. ?
Old Nov 7, 2005 | 03:31 AM
Schooler's Avatar
I would say the CV joints
Old Nov 7, 2005 | 03:58 AM
seaflea's Avatar
the Cvs may be the first to break, but the Idler arm is the first to bend and hit the frame. Seems to be the weakest point on IFS.
Old Nov 7, 2005 | 05:05 AM
midiwall's Avatar
CV's... It's the only thing I've actually broken, and I off-road with my right foot.
Old Nov 7, 2005 | 06:16 AM
oly884's Avatar
Guest
Well it's either going to be the CV boot or the CV joint. I never broke a CV joint, but I did break a couple boots in my time.
Old Nov 7, 2005 | 06:40 AM
Intrepid's Avatar
As stated above, CV's are the worst. Tie rod ends will go and eventually you could have some steering rack issues. It all depends on tire size and how much abuse you give it.
Old Nov 7, 2005 | 07:51 AM
Fink's Avatar
Depending on tire size and abuse...the idler arm is WEAK, been there done that! I'd get the idler arm brace from Downey.
Fink
Old Nov 7, 2005 | 08:06 AM
Churnd's Avatar
Fink
While it rarely ever actually breaks, it can get bent and become very annoying if your rig is a daily driver. Especially if you have bigger tires. Take it from me and save yourself a lot of headaches in trying to figure out why your truck's front end won't align properly and get that idler arm brace.
Old Nov 7, 2005 | 08:12 AM
deathrunner's Avatar
or the total chaos idler, but it's bit more $$
icentropy
Sep 16, 2020 02:47 PM
XtraCab
Apr 12, 2020 05:25 AM
thefishguy77
Jul 30, 2015 10:59 AM
akaphilly
Jul 9, 2015 02:34 PM
skoti89
Jul 6, 2015 07:45 PM
