1999-2002 4runner Hitches
Old Nov 7, 2005 | 07:09 PM
tarheelrunner's Avatar
I'm planning on doing a 2" body lift over my Christmas break, and I am trying to get everything planned out. I really don't won't my hitch to hang down 2", so I was going to run an idea by everybody and see if it will work.
As far as I know, there are two models of OME 1999-2002 4runner hitches, both being one piece. On one model the reciever is flush with the rest of the hitch, and on the other the top of the reciever is flush with the bottom of the rest of the hitch (So there is a square reciever hanging down about 2"). I have the hitch where the reciever hangs down, and because the hitch is one piece, flipping the thing is not an option. But would it be possible to use a hitch where the reciever is flush and flip it? Also, I could always use a washer or two to space a few 1/8s of an inch if it doesn't quite fit.
Has anybody ever tried this, or will the inside of the frame even allow the hitch to flip? Any help would be appreciated, especially from you guys who have a hitch where the reciever is flush!
Old Nov 7, 2005 | 07:13 PM
SnoViking's Avatar
you might be able to flip it, but i wouldnt bank on the washers as spacers... that would put more sheer torque on the bolts which isnt good...
Old Nov 7, 2005 | 07:18 PM
ecchamberlin's Avatar
I have been thinking about this also. I have taken mine off a few times to see what can be done with the one piece hitch. Only thing I can think of is to cut off the part that has the 90 degree angle and has the bolt holes for the frame and reweld them back on 2"s lower. Make any sense?
I have been considering just switching to a Hidden hitch but you would still have the BL gap but more clearance.
Old Nov 7, 2005 | 08:16 PM
98LimitedCustomized's Avatar
There really isn't much to a hitch, for what they sell for you could easily get one custom made after you're done body lifting... it would be the safest route because trying to space them in any was is trouble.
Old Nov 7, 2005 | 08:37 PM
Yeah the spacing thing probably is a pretty stupid idea, don't tow much more than a 5x8 utility trailer but its still probably not too safe.
How hard would cutting through a trailer hitch and rewelding be? I hadn't really thought of that before, but there has got to be a reasonable easy way to alter either the OEM hitch or a Hidden Hitch to it fit with a 2" body lift.
Any of you guys in the custom hitch business?
Old Nov 7, 2005 | 08:44 PM
User 051420's Avatar
PM Calrockx...IIRC, he has his chopped to fit.
Old Nov 8, 2005 | 05:13 PM
Thanks gapgay--Calrockx said he got one custom made so thats definitely one option.
Anyone else tried working with the stock hitch?
Old Nov 8, 2005 | 05:18 PM
garrett1478's Avatar
flip it over?
Old Nov 9, 2005 | 07:18 AM
paddlenbike's Avatar
I wasn't aware 3rd gen 4Runners had different hitches. My 2000 has the hitch with the receiver hanging 2.5" below the rest of the assembly. I've been thinking about cutting it off and welding it so it's flush with the rest of the hitch, much like the 2nd gen 4Runner hitches:
Old Nov 9, 2005 | 07:22 AM
bamachem's Avatar
i have one of the flush ones from my 99 for sale...
make me an offer - you pay actual shipping from a UPS retail location in zip 37934...
Old Nov 9, 2005 | 07:56 AM
Pic? I have never seen one.
Old Nov 9, 2005 | 09:02 AM
bamachem's Avatar
just pulled from my runner for the bumper swap.
the hitch receiver is black and is the OEM square tube type that is a "shallow mount" and doesn't hang down a whole lot below the rear bumper. comes with mounting bolts/buts and the OEM tie down loops that attatch to the frame. (pics to come shortly)
https://www.yotatech.com/forums/show...655#post739655
shown w/ a 1" body lift and standard orientation.
Old Nov 9, 2005 | 12:01 PM
Bamachem: do you think with a little grinding it would be possible to mount that hitch upside down so it would be close to the bumper after the 2" body lift?
I'm looking at buying a modified hitch from Charles, but if that doesn't work I'll let you know because the hitch you have is definitely my 2nd choice....even with a 2" gap (if I can't flip it) it would look better than the one I have right now.
Also, any idea on shipping to 28504?
Old Nov 9, 2005 | 12:09 PM
bamachem's Avatar
i'll check it this evening when i get home since i now have bare frame rails and can hold it up for a check-fit.
if i recall correclty, it interferes w/ the spare tire hoist crossmember, but just barely and could easily be cut to fit around the crossmember.
it's probably 40#, but due to size, would be billed at a full 70# rate.
size is approx 10"h X 30"w X 24"d
would include all bolts/nuts.
my zip is 37934 if you want to check UPS from a UPS store...
Old Nov 9, 2005 | 05:14 PM
I checked on the UPS site and shipping is only about $32 (if the do charge it as 70#). Anyway, if you think flipping the hitch will work then I'll be more than happy to take if off your hands!
Old Nov 9, 2005 | 05:49 PM
Fink's Avatar
Get the one bamachem has and then once you get your BL put on, take some measurements and get some custom brackets made...thats what I was gonna do.
Fink
Old Nov 16, 2005 | 05:22 PM
Bamachem- did you ever get a chance to flip the hitch on the bare frame rails to see if it will work?
Old Nov 17, 2005 | 03:45 AM
bamachem's Avatar
haven't yet. i'm taking a day off tomorrow to work on the rear steel. i'll make a note to try it out then and take a pic.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
