Supercharging the '96 Taco...
Old Nov 4, 2005 | 07:05 AM
boraxman's Avatar
What exactly is the deal with sc on '96 Tacos? Ive heard its something to do with the ECU, they were changed in 97 or something.
Has anyone done a 96 or earlier Taco or is it possible at all?
Old Nov 4, 2005 | 07:41 AM
ken.vs.ryu's Avatar
Car and Driver had a shootout of tuners and one came with a Toyota Truck with a camper. It was turbo charged. It blew a cylinder in the competition and drove home on 3 cylinders.
Old Nov 4, 2005 | 08:33 AM
MTL_4runner's Avatar
Definately possible, lots of reading for you on that:
http://www.gadgetonline.com/4run.htm
Old Nov 4, 2005 | 10:21 AM
midiwall's Avatar
Yeah... like Jamie said, a LOT of folks have S/C'd that engine. Not a problem, but to do it right, there's more to it than bolting in the S/C.
Check the link that Jamie's posted. It's where 97.3% of us have started.
Old Nov 4, 2005 | 10:59 AM
boraxman's Avatar
I looked at the link, didnt talk about the '96 Taco. If you look at the applications for the TRD SC's its always for 1997-up Tacos and 96 up 4Runners. Just wondering why '96 Tacos are excluded.
Old Nov 4, 2005 | 11:19 AM
midiwall's Avatar
If we're talking about the 3.4L 6 banger, then it's the same engine that's in my truck. The S/C bolts on the same, the fuel delivery issues and fixes are the same, the timing issues and fixes are the same.
Drop a line to Gadget at URDUSA or through his private site above and ask.
Old Nov 4, 2005 | 11:25 AM
boraxman's Avatar
Yup talkin 3.4 here. Thanks for the replies so far....
Old Nov 4, 2005 | 12:03 PM
TRDOLMAN's Avatar
As Mark has stated, the supercharger will fit with no problem. The problem, and the reason TRD and Toyota says it won't work on your 96, is that you and have a different ECU. On the earlier model ECUs like yours, 95-98 year models, the ECU continues to try and trim fuel even in boost. This is unacceptable because under boost conditions, the ECU is still trying to get the fuel mix to 14.7 AFR giving you very lean running conditions doing definite damage to your engine. The 99 and newer ECUs don't do this. However, you can still run a supercharger safely if you use URD's fuel kit that is designed for your year truck:
http://www.urdusa.com/product_info.p..._id=1230100017
Read the section about the earlier trucks and you will see what I mean.
Old Nov 4, 2005 | 12:46 PM
boraxman's Avatar
I understand, but I think its more than just that. If you look on Ebay at SC's for instance, you will notice the application on all of them is 96 up 4Runner and 97 up Tacoma.
I think I will throw the question to Gadget or maybe he may chime in.
Old Nov 4, 2005 | 07:15 PM
TRDOLMAN's Avatar
Well, I have told you the answer to your question but if you doubt me then continue searching. Gadget will tell you the same thing I did.
Old Nov 4, 2005 | 08:30 PM
Randomness's Avatar
What does that have to do with this?
And I'd listen to the guy with 300+ whp on his Taco
Old Nov 5, 2005 | 07:08 AM
boraxman's Avatar
Cool, just want to make sure before I go spending $3k.
Old Nov 5, 2005 | 08:21 AM
TRDOLMAN's Avatar
Before you drop your money on the supercharger, check with URD and make sure they have the fuel kit for your 96. The supercharger will physically fit the engine but it is imperitive that you have URD's proper fuel controller for it to work right. A good fuel kit is a must in my opinion for any supercharger application no matter what the year or ECU configuration.
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
anniesball
Sep 7, 2015 11:20 AM
