Supercharging the '96 Taco...
What exactly is the deal with sc on '96 Tacos? Ive heard its something to do with the ECU, they were changed in 97 or something.
Has anyone done a 96 or earlier Taco or is it possible at all?
http://www.gadgetonline.com/4run.htm
Yeah... like Jamie said, a LOT of folks have S/C'd that engine. Not a problem, but to do it right, there's more to it than bolting in the S/C.
Check the link that Jamie's posted. It's where 97.3% of us have started.
I looked at the link, didnt talk about the '96 Taco. If you look at the applications for the TRD SC's its always for 1997-up Tacos and 96 up 4Runners. Just wondering why '96 Tacos are excluded.
Drop a line to Gadget at URDUSA or through his private site above and ask.
http://www.urdusa.com/product_info.p..._id=1230100017
Read the section about the earlier trucks and you will see what I mean.
Originally Posted by TRDOLMAN
As Mark has stated, the supercharger will fit with no problem. The problem, and the reason TRD and Toyota says it won't work on your 96, is that you and have a different ECU. On the earlier model ECUs like yours, 95-98 year models, the ECU continues to try and trim fuel even in boost. This is unacceptable because under boost conditions, the ECU is still trying to get the fuel mix to 14.7 AFR giving you very lean running conditions doing definite damage to your engine. The 99 and newer ECUs don't do this. However, you can still run a supercharger safely if you use URD's fuel kit that is designed for your year truck:
I think I will throw the question to Gadget or maybe he may chime in.
Originally Posted by ken.vs.ryu
Car and Driver had a shootout of tuners and one came with a Toyota Truck with a camper. It was turbo charged. It blew a cylinder in the competition and drove home on 3 cylinders.
And I'd listen to the guy with 300+ whp on his Taco
Well, I have told you the answer to your question but if you doubt me then continue searching. Gadget will tell you the same thing I did.
Cool, just want to make sure before I go spending $3k.
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
anniesball
Sep 7, 2015 11:20 AM
