My check engine light is on (Code DTC PO171)
Old Nov 11, 2005 | 12:09 PM
pfbmgd's Avatar
A week ago my check engine light came on .I took it to a garage and it came up as Code DTC PO171 .One thing is that my print out says 3.4L motor and I have a 2.7L .Will the reading make a diffence ?
The possible problems according to the print out .
-Air intake hose is loose
-Fuel line pressure
-Injector blockage
-Heated oxygen sensor
-Mass airflow semsor
-Engine collant tempraur(ECT)sensor
I now have 148 000km on the truck .I did a oil change a week before the light turned on .I reset the computer by unplugging the battery for a few hours .The light came on again after a few days .Any ideas ?
Old Nov 11, 2005 | 12:16 PM
colsoncj's Avatar
Does it come on and stay on, or come on and go off.
Old Nov 11, 2005 | 12:21 PM
pfbmgd's Avatar
It stays on all the time .
Old Nov 11, 2005 | 01:07 PM
WATRD's Avatar
That's a common code. Clean your MAF and 99% of the time it goes away. It is probably caused by overoiling the K&N filter.
From the FSM for the 2.7
System too Lean (Fuel Trim)
 Air induction system
 Injector blockage
 Mass air flow meter
 Engine coolant temp. sensor
 Fuel pressure
 Gas leakage on exhaust system
 Open or short in heated oxygen sensor (bank 1 sensor 1) circuit
 A/F sensor (bank 1 sensor 1)
ECM
But I will bet you $1.00 that cleaning the MAF makes the problem go away.
Old Nov 11, 2005 | 01:16 PM
pfbmgd's Avatar
Where is the MAS ? How do I clean it ?
Old Nov 11, 2005 | 01:23 PM
WATRD's Avatar
Just inboard of your airbox.
But, you should read up a bit on the technique for cleaning it. It's VERY fragile and VERY expensive, so you want to handle it like you would your <censored>s. There ar a few write ups around, so familiarize yourself with the process BEFORE you decide if it's something you want to take on.
Old Nov 11, 2005 | 01:57 PM
Bob_98SR5's Avatar
pf,
it's MAF, not MAS. rob's pic and advice is good. depending on your year vehicle, there are several writeup on "cleaning MAF"
bob
Old Nov 13, 2005 | 05:31 AM
pfbmgd's Avatar
I cleaned the MAF last night .It did look a bit dirty .i`ll report back in a couple of days if that was the problem .
Old Nov 13, 2005 | 06:22 AM
cruzin1a's Avatar
I tripped this code by running out of gas. My fuel gauge is currently not working. It would seem that my trailer lights might have shorted a few chips in the dash and maybe the sending unit. However in troubleshooting the code I discovered that running out of gas will trigger this code.
Old Nov 13, 2005 | 05:37 PM
3.4v6's Avatar
pfbmgd
your sig says your running a k&n . my truck kept throwing that code for 2 weeks and i couldnt figure it out ... it was the k&n, and when i put the stock filter back in ... no more code
clean you MAF and swap the filters , it's worth a try
Old Nov 13, 2005 | 07:12 PM
pfbmgd's Avatar
I had the filter installed 2 years ago with no codes .I cleaned the MAF and no codes so far .
Old Dec 11, 2005 | 10:40 PM
cruzin1a's Avatar
Well my code came back so I decided to follow the advice here and clean the MAF. It's been about a week since I cleaned it per the instructions here. I passed the inspection and so far it's not come back on. Hopefully we nailed and thanks for all the great info.
Old Nov 2, 2007 | 02:53 PM
danberg's Avatar
I had the same "check engine" light come on when I was going to the Toyota dealership to have my oil changed by co-incidence.
They replaced the engine control computer (#89661-02K41) per Toyota service bulletin.
My car, 2008 Matrix 4 cylnd. If this helps you at all.
Old Jul 14, 2009 | 10:56 AM
hult's Avatar
I went to Advanced Auto Parts and had them check my 99 4Runner with the diagnostic machine because I was getting the check engine light and the Code was PO171 (too lean). I took the advice on cleaning the MAF sensor with the MAF cleaner CRC and it worked. My check engin light went off after two days and my truck is getting better gas mileage and running smoother. thanks for the advice.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
