2nd gen key fob
Old Sep 1, 2005 | 06:48 PM
WFBT2's Avatar
2nd gen key fob
Does anybody know how to program a 2nd gen key fob? I tried everything I found in seaching this site but nothing has worked. I have 2 new fobs and the dealership wants $70 to reprogram each fob. Thanks for any help.
93 4Runner SR5 V6 Auto.
Old Sep 1, 2005 | 09:16 PM
94x4's Avatar
Guest
I know that if you actually do a Search for "programming alarm" you will find the info that you need.
Old Sep 2, 2005 | 04:05 AM
WFBT2's Avatar
Thanks 94x4 for your input but I know what I've already done. Found a bunch of great info on 3rd gens that didn't work on my 2nd gen. I don't have any buttons, green or otherwise, on the controler, nothing under the drivers seat, and my neighbors did look at me funny as I locked and unlocked my doors for hours. So I'm still looking for some helpfull info.
Old Sep 2, 2005 | 05:27 PM
94x4's Avatar
Guest
Uh, if you're able to "...lock() and unlock your doors for hours" with your keyfob's, then I'd have to say that you've managed to get them reprogrammed..., would'nt you?
Old Sep 3, 2005 | 01:13 PM
94x4's Avatar
Guest
Your key fob should have one(1) button and one(1) red l.e.d. on the face of it..., if you don't, then you don't have a 2nd. gen. OTOT8 or 30923 factory alarm system, period.
Old Oct 15, 2005 | 09:53 AM
GM TURBO's Avatar
I'll make my first post by hopefully helping someone
2nd Gen factory alarm reprogram.
Step 1: Turn ignition to the ON Position.
Step 2: Turn Valet on, the off - Once. The horn may sound. The system is resetting itself.
Step 3: Turn ignition off then on.
Step 4: Turn the valet switch On and Off 4 times - the horn will sound 4 times.
Step 5: Push the button on any transmitter. Horn will sound once.
Step 6: Turn the Valet switch on then off - Once. The horn will sound 5 times indicating all transmitters are erased from the system's memory.
Step 7: Push the button on the transmitter you want to keep. Horn will sound once.
Step 8: Repeat Step 7 on any other remotes (max of 4).
Step 9: Exit programing mode by turning ignition off
Step 10: Verify operation.
Now, can someone tell me where to buy a transmitter so I can see if this works
Old Oct 15, 2005 | 10:50 AM
Strap22's Avatar
Sponsoring Vendor
Welcome to Yota Tech
I am impressed that your first post was this. Anyway you can get anything you need for your 2nd Gen 4Runner from www.trdparts4u.com if you can't find it listed just e-mail Barb at info@trdparts4u.com or you can PM me.
The Transmitter part number is 08191-00870 List $86.68 Yota Tech price $58.64. I hope this helps............
Old Oct 15, 2005 | 03:30 PM
GM TURBO's Avatar
You can thank the previous owner for having the alarm manual w/programming addendum and the dealership for not giving me the remote I just happened to have it on the desk and was doing a search (he says as people read in disbelief) for the remote part number.
And now I have the part number I need and link to find 'em cheap
kapeket
Aug 23, 2015 12:51 PM
jmyer72
Aug 20, 2015 07:55 AM
vanion2
Jul 29, 2015 06:17 PM
Hamonacracker
Jul 17, 2015 08:33 AM
Steezy96yota
Jul 6, 2015 10:00 AM
