Can this be done on a 3.0 ? :think:
Old Aug 30, 2005 | 04:29 AM
2003mikem's Avatar
I have a 1991 4runner 4x4 3.slow
I was wondering if something similar to this could be done ?
please see link
http://cgi.ebay.com/ebaymotors/ws/eB...%3A1%3A1v_home
Old Aug 30, 2005 | 07:26 AM
94x4's Avatar
Guest
If you're asking whether or not the 3.o can be supercharged..., the answer is "yes".
If you're asking whether or not the "Gator" system would work..., I can give no input without further information of the system's application.
Old Aug 30, 2005 | 08:10 AM
2003mikem's Avatar
Thank you for your input. I will be trying something similar because of it simplicity. Also I was watching trucks on TNT TV and saw a turbo system the was mounted and ran of the tail pipe behind the muffler, sound great but not practical of road. Or the fact I live in the rust belt. LOL
I work for a crane company and have access to a full machine shop, that will help.
Will post my findings when and if I get it done.
Old Aug 30, 2005 | 08:49 AM
Ironmike4x4's Avatar
Sounds like a scam to me.
Old Aug 30, 2005 | 09:01 AM
2003mikem's Avatar
I would not buy one I would manufacture one similar.
Old Aug 30, 2005 | 09:34 AM
elripster's Avatar
please see link
People have been supercharging engines all sorts of ways for years. My great uncle used to do so with smog pumps. So, the book is not necessarily scam and could be a good source of info.
Frank
Old Aug 30, 2005 | 10:35 AM
Flamedx4's Avatar
Limiting the boost properly (and smoothly) is probably the hardest hurdle for the home builder. Then there's reliability - longevity of the components (bearings etc.) And of course managing the fuel mixture.
Old Aug 30, 2005 | 10:42 AM
2003mikem's Avatar
I don’t know that much about them yet as I have not read many books on turbo yet. But isn’t that the blow of valve job? as far as reliability of parts, I will use a constant oil bath for the bearing case and turbo. That is the plan for now but we will see after I have read up on turbo’s.
Old Aug 30, 2005 | 05:21 PM
94x4's Avatar
Guest
DUDE! You work for "Crane", as in "Crane cams"???? WTF?!?
"B&M" has a pretty cool side draft setup that would readily fit under the hood and hook up without all of that much modding..., unless you're into building one yourself.
Old Aug 30, 2005 | 05:32 PM
EWAYota's Avatar
i think it might be more for construction cranes
Old Aug 30, 2005 | 05:35 PM
94x4's Avatar
Guest
Yeah, I see that now..., missed it on the first pass.
I guess that means that I've had enough .
Old Aug 31, 2005 | 03:28 AM
2003mikem's Avatar
We build in door cranes. Like bridge cranes and jib cranes www.contrxcranes.com
Old Aug 31, 2005 | 06:24 AM
gwhayduke's Avatar
To run the turbo at sufficient speeds to produce boost, you'd have to really step up the RPM's coming off the crank to something like 10,000 RPM's or more.
Save your money, drive slow, live long, have children, prosper.
Old Aug 31, 2005 | 07:31 AM
94x4's Avatar
Guest
First off, I thought that we were discussing "superchargers", not "turbos", as they are trully two separate animals.
Secondly, you see stepping the crank's RPM's up to at least 10,000 as being an issue??? Inasmuch as 2003mikem does work for a crane manufacturer, lifting that is, I'll bet that he's already got an inside track on stepping up the RPM's..., can you say "reduction gearing"???
Old Aug 31, 2005 | 07:43 AM
2003mikem's Avatar
Well as far as the rpm, I don’t know a thing. If re gearing is an issue I can fab a gear box.
As I understand a turbo charger is driven by the exhaust. A super charger is driven by a belt or so on. In the link it shows a turbo driven by a belt. which would be called a super charger. Maybe, Maybe not. My thought is this is less complicated than reengineering the wheel since there is almost no room under the hood. As long as I can get a belt to drive it.I have seen turbo’s on 1 -2 4runners with the 3.0 but I would like something a little less complicated. Maybe it inst less complicated.
Once again I do not know a lot about turbo”s or superchargers. Just enough to want to attempt something or possible make a big mess of my 4unner.
p.s. if it matter it is rebuilt .30 over new cams pistons rods etc.
Old Aug 31, 2005 | 06:58 PM
Bumpin' Yota's Avatar
Try
105,000 - 200,000 rpm pending the compressor wheel used...
Old Aug 31, 2005 | 08:55 PM
94x4's Avatar
Guest
Originally Posted by Bumpin' Yota
Try
Yeah, what he said!
Seriously though, that's a "supercharger" setup in the link and their application is considerably simpler than a "turbocharger" in that you can almost readily bolt on a pulley driven supercharger whereas with a turbo you've alot of plumbing and tuning boost parameters that you'd have to go through.
Admittedly though, the one major drawback to charger usage over turbo usage is that the charger relies on the engine itself to create "boost" or increase compression by slaving itself to the engine's crank pulley which has a tendency to create a drag on the engine, whereas the turbo relies on the waste product of the engine, i.e. the exhaust, to create "boost" and so, puts a way less, if any, drag on the engine itself.
Old Sep 1, 2005 | 04:32 AM
gwhayduke's Avatar
Take a look at the eBay pic...it's the compressor portion of a turbo with a box mounted to contain the drive shaft. Finally a pulley is mounted drive the compressor. If, as Bumpin' says, you have to run 100K rpms, you have to multiply your crank rpms about 400 times. Not quite sure how you'd do it or how long a stock pulley would last before the vibrations killed it and the bearings.
Old Sep 1, 2005 | 06:41 AM
there actually are superchargers that use a turbo compressor wheel with a BIG gear box. Seen em in action here. Known as centrifical superchargers iirc.
Old Sep 1, 2005 | 01:09 PM
94x4's Avatar
Guest
WORD!
"Paxton" incorporates alot of centrifical gearing in their applications..., just think "block and tackle" to get a visualization of what's involved.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
