Starting Help
Old Sep 6, 2005 | 01:22 PM
Keggo's Avatar
Starting Help
The last week or so, I've noticed it the cranking over sound has gotten really slow. This weekend, I tried starting the truck up and nothing... just a lot of clicking (from starter?). I haven't tried to see if the accessories still work because I don't want to drain the battery anymore than it is. The battery has been in the truck since I bought it last October... If I need a new battery I'm just going to get an Optima... Any suggestions as to what may be causing this besides bad/old battery?
Old Sep 6, 2005 | 01:26 PM
celica's Avatar
first thing to do would be to check the status of your battery. If your battery is good then you could have two issues
1) alternator not charging your battery - therefore wearing it down
2) starter contacts are dirty or worn out
Matt
Old Sep 6, 2005 | 01:29 PM
Keggo's Avatar
Cool... my battery's walls look like they're warped a little bit. I did the test where someone gave me a jump and I let the truck run for a bit and while it was running I disconnected the positive cable from the battery and it ran fine... is that an alright way to see if my alternator is doing it's job?
Keggo's Avatar
I should probably just buy some new starter contacts and just replace them just in case, eh?
Old Sep 6, 2005 | 01:42 PM
TacomaTRD's Avatar
How dirty are the battery terminals? maybe you just have a bad connection?
Old Sep 6, 2005 | 01:51 PM
Keggo's Avatar
I just cleaned the battery terminals with Sprite the other night...
Old Sep 6, 2005 | 05:27 PM
Keggo's Avatar
Well, I bought an Exide Orbital battery (Same internals as Optima), got an electrical test verifying that my charging system is still good and also the starter is good. The truck cranks right up now!
Old Sep 6, 2005 | 07:23 PM
tabb's Avatar
Originally Posted by Keggo
Cool... I let the truck run for a bit and while it was running I disconnected the positive cable from the battery and it ran fine... is that an alright way to see if my alternator is doing it's job?
2 things:
1) always disconnect the negative terminal before you do the positive - to prevent shorting (lots of sparks BAD!!!).
2) NEVER disconnect the battery while your engine is runnning - When you disconnect the battery terminal while the car is running, the alt jumped to its max output. While this may tell you your alt is charging, it also puts an incredible strain on it and could burn it out or at least shorten it's life span....you got lucky!!
Old Sep 6, 2005 | 07:30 PM
Ironmike4x4's Avatar
Originally Posted by tabb
2 things:
True as well as the battery acts as a buffer during voltage spikes.
Old Sep 6, 2005 | 07:54 PM
Keggo's Avatar
cool... that's the first (and last) time I've done it... so, I'll know better next time!
Old Sep 7, 2005 | 08:22 AM
celica's Avatar
Be sure to charge your battery as the alternator will not do it correctly. An alternator is designed to simply top up a battery, not charge it. If your battery was low and you don't charge it, it will cause your alternator to run wide open (as opossed to on-off-on-off, etc) and will burn itself out fairly quickly.
Matt
Old Sep 7, 2005 | 08:30 AM
Keggo's Avatar
Cool, I just got the new one, so we should be good. The old battery looked like hell... I also changed out the battery cable clamps and put dielectric grease on the battery posts. I'll get pics one of these days. Thanks for the help.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
