Integration Relay - 98 4runner
Old Aug 31, 2005 | 04:56 PM
husker267's Avatar
I'm trying to find exactly where the integration relay is in a 98 4runner. I need to test it to figure out why I have no radio, dome lights, or power door locks/alarm. I keep on blowing the dome light - 15A blade fuse and need to find the short/ground. I've tested it between the battery and the 15A. The next step is between the fuse and the integration relay. Thanks in advance.
Old Aug 31, 2005 | 05:57 PM
sho510's Avatar
On the interior fuse panel, below the fuses, on the front side. It's the big box that hugs the fuse box, and it is connected with a 12-terminal connector. If you want it to work while you are testing it, you will have to make a bunch of jumper wires to connect it to the fuse block to maintain its connections. Apparently the head nerds at Toyota liked Ford's Taurus idea (4 relays in a box) so much they stuck it in most Toys since 92 or so. They're located in the same spot as yours on most Yotas, car or truck.
Old Aug 31, 2005 | 06:38 PM
Ironmike4x4's Avatar
*Thread hijack* Very impressive Sho510! Your first post as a newb on this board and an informational one. Are you a Toyota Technician or just a big time gear head? Anyways, I just had to compliment you on the knowledge you have.
Doug4320
Mar 24, 2018 10:11 PM
msane99
Jul 17, 2015 10:13 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
