leaking differential ....breather is fine
Old Sep 7, 2005 | 09:45 PM
spacewrangler's Avatar
it's leaking right at the very bottom where the solid part of the axle is connected to the thing the drive shaft goes into (not sure what that part is called between the drive shaft and the axle....but it's the big round seal next to the axle that is leaking ..not the pinion seal) it appears that that gasket is made of some kind of paper because i can see some if it sticking down....almost like it was replaced before and wasn't aligned properly. i tried tightening down the nuts/bolts but it's still leaking
how much can i expect to pay to have that seal replaced. ...and is there a better seal to use other than one that is made of paper?
thanks in advance!
Old Sep 7, 2005 | 09:58 PM
jimbo74's Avatar
other than the paper one people use the form in place gasket... do a search for it... oyu are talking about the differential or third member seal
Old Sep 7, 2005 | 10:31 PM
it's definatly the diff. seal. ...i already did a search and all i found was to check the diff. vent and it appears to be fine.
i'm not sure what the 3rd memeber is. ..is it the cone shaped part that bolts on to the axle that the drive shaft goes into?
Old Sep 7, 2005 | 10:53 PM
Tacoma Dude's Avatar
I paid around $200 to get the third removed and a bolt replaced. I'd imagine that it would be about the same amount to replace the gasket.
Old Sep 7, 2005 | 11:28 PM
Elton's Avatar
i think i have the same problem i think the fluids in the diffs have never been changed i got about 163k on my truck
Sleaker
Aug 26, 2020 06:03 AM
Ladythump
22
Nov 9, 2015 08:53 AM
nick b
Jul 11, 2015 04:38 AM
Avenged
Jul 9, 2015 07:55 AM
AaronM
Jul 8, 2015 07:15 PM
