3rd Gen. Low erratic Idle?
Old Sep 4, 2005 | 01:48 PM
RunnerUp's Avatar
Hey I have a 2002 SR5 4WD with the 3.4 in it, a couple months ago I was running in drive at idle around 7-800 RPM. now it has dropped to 550-600RPM, anyone know what can cause this? I checked my air filter and it seemed clean enough (its a K&N).
Old Sep 5, 2005 | 01:38 PM
RunnerUp's Avatar
alright, cleaned my airfilter just to be sure and it didnt fix the problem, how can i adjust the idle, or should i be cleaning something to try to fix this?
Old Sep 6, 2005 | 05:33 AM
MTL_4runner's Avatar
The likely culprit is a dirty throttle body (see cleaning the throttle body...) :
http://www.4x4wire.com/toyota/mainte...tenancep5.html
You might also check your MAF since many experience problems with those K&N filters. I most don't recommend them on this board since it does tend to foul the MAF over time (I'd sell it on eBay and get an Amsoil instead).
Old Sep 6, 2005 | 12:55 PM
RunnerUp's Avatar
hey, thanks for the link, i will be doing all of that tomorrow morning, you are actually the first person ive ever heard that didnt like k&n, is an amsoil similarly priced?
Old Sep 6, 2005 | 04:21 PM
Unhappy99's Avatar
My 99 will do this, and not long after will light the CEL with P0171.
Clean the MAF. Be sure to get down inside where the actual hotwires are and not just the IAT amber bulby thingy.
Old Sep 7, 2005 | 06:17 AM
Check this out regarding K&N:
http://www.gadgetonline.com/AirInduc...0air%20filter:
Old Jan 1, 2022 | 05:42 AM
Toyota4R08's Avatar
Problem found?
Did you found the problem? I have the same issue on my 99 3.4. Sometimes idling at 550-600rpm. Thanks!
Old Jan 1, 2022 | 09:20 AM
fierohink's Avatar
low idle is usually and air issue. Have you tried removing the air filter ( to eliminate potentially clogged filter element) or spraying carb cleaner along all the pipes (to check for leaks)?
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
