98 Tocoma Squealing On Start
Old Sep 2, 2005 | 08:40 PM
LarsTheMech's Avatar
When I start up my truck, I get a loud squealing that lasts maybe a minute if not only a few seconds. As the sound stops, I get a little surge in power/clutch type engagement from the truck. I have also noticed that at higher speeds, I can hear a high pitch sssssssss, very faint though. Maybe a bearing going out in the alternater or clutch? Thanks for your help with this question.
Old Sep 4, 2005 | 07:46 PM
TACOMANATOR's Avatar
Most likely a belt that is slipping. Check the tension on your belts.
Old Sep 5, 2005 | 02:24 PM
RuffRider's Avatar
I just replaced an alternator with a bad bearing. If the bearing is bad it doesn't stop. It just gets louder the warmer it is and the longer it runs.
Old Sep 5, 2005 | 02:27 PM
jimbo74's Avatar
i am with tacomanator, it sounds liek a belt slipping... check the tension
Old Sep 5, 2005 | 04:13 PM
Intrepid's Avatar
definitely a belt, like they said, check the tension, if it is really worn throw on new belts, if not, tighten them a bit and hit them with some belt lube.
Old Sep 6, 2005 | 05:29 AM
MTL_4runner's Avatar
Could be the alternator or the belts, check both.
Check belts for wear and replace as needed or retension.
Old Sep 8, 2005 | 05:47 PM
Belt lube? We wouldn't want those belts sticking now would we.
It's belt dressing isn't it?
Old Sep 9, 2005 | 04:58 AM
.....yeah, I heard grease on the belt helps it stop squeeking.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
