HELP my rig is bleeding to death
Old Sep 1, 2005 | 07:22 AM
GA95Runner's Avatar
ok so the grease monkeys at my local jiffy lube cross theaded my oil pan and now im leaking pretty badly, I get about a hand sized oil spot parking overnight. I have little money so I'm gonna have to do the work myself, i have a haynes repair manual, I just need to find a new oil pan cheap and JC whitney doesnt carry toyo oil pans....any ideas people??? also any advice on the labor would be helpful..... I am located near atlanta
its a 1995 v6 sr5
Old Sep 1, 2005 | 07:25 AM
shiftless89's Avatar
Go directly back there and have them repair it, they have the means. speak directly with the manager, and express your discontent. try to get a new pan out of them.
are you sure its cross threaded or did they just forget the gasket?
Old Sep 1, 2005 | 07:30 AM
jvangun's Avatar
I find that if you keep your cool, show the receipt from the last time you got your oil changed, they should help you out. I had what I thought was a problem and ended up being my ignorance. They were very cool to help out.
Old Sep 1, 2005 | 07:37 AM
GA95Runner's Avatar
the gasket is on there, the oil is coming from around it. they told me it was already leaking and I know it wasn't. This came FROM the manager. what he had said it looked like it was 'previously cross threaded.'
Old Sep 1, 2005 | 07:39 AM
GA95Runner's Avatar
would it be possible to just put a bigger/wider gasket on the oil pan plug?? I have also tried silicone and it just washed away with the leaking oil
Old Sep 1, 2005 | 07:42 AM
the_4runnin'_beast's Avatar
you should be able to get an over-sized drain plug to go in there. its just slightly bigger than usual and creats new threads for itself. it may help.
Old Sep 1, 2005 | 07:48 AM
GA95Runner's Avatar
hmm...that may be a lot cheaper than replacing the g- damned oil pan...
im gonna be real mad though having to change my oil for the second time in 3 days
Old Sep 1, 2005 | 07:50 AM
4Crawler's Avatar
That is one reason I do my own oil changes. It costs less and you can do it right.
For sure try either an oversized plug and/or try cleaning up the existing threads with a threading tap if you have one.
Old Sep 1, 2005 | 11:35 AM
GA95Runner's Avatar
has anyone here seen or used the oil filter relocation kits??? they look like they could make life easier....
Old Sep 1, 2005 | 01:07 PM
fierohink's Avatar
I've done Amsoils bypass filteration set-up on my Superduty. It's a filter relocation system with another oil filter that's like super tight and does some crazy like 1 micron filtration.
ladybugRC
458
Aug 21, 2020 10:41 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Shagool22
Sep 28, 2015 07:53 PM
Toys4parts
Sep 26, 2015 01:56 PM
