Ignition Wires
Old Sep 6, 2005 | 07:03 PM
steakknives's Avatar
Ignition Wires
I have a '91 4Runner and am replacing the ignition wires. I broke the distributor cap trying to remove the end of one wire... but it was all fuzed in there. But that's not the problem. I also can't seem to open a clip that is holding some wires together/off the engine. They are on the left side. I know this is a terrible description, but I can email pics if you want. I will try to post some when not so tired.
If anyone can help I'd be greatful!
Dylan
Old Sep 6, 2005 | 07:10 PM
DH6twinotter's Avatar
Hey! Welcome to the forums!
You should just replace the cap. You can get one from Toyota for cheap. I would probably be a good idea to replace the rotor button while you are at it too.
As far as the clip goes, I'm not sure. I don't remember any clips on mine other than the one that the wires kind of snap into (sort of like the 4 that run along the top of the timing cover). I'll look in the morning though.
Well, have fun
Daniel
Old Sep 7, 2005 | 10:04 AM
Yeah, it is different than the four on the timing cover... (which I have to replace too) to the left and closer to the other ends of the wires. It just binds two of them together, and is a pain to get off. I may just cut it and clamp them back on.
Yeah, I am going to replace the cap too. It's something like $12, no biggie.
Thanks a ton.
Old Sep 14, 2005 | 06:14 PM
Question Two more quick questions
So I broke the distributor cap and got another. I am going to cut the clip off, and get a metal clamp and reattach the new cables (once in). Finally, though, I want to ask:
1. What kind of grease should I use when reinstalling the new distributor cap?
and...
2. Is it important/what kind of electrical connection lubricant should I use on the ignition wire connections. Seems pretty important to me, seeing as my last cables were welded to the distributor cap. Some suggestions would be greatly appreciated.
Thanks a lot for all your help!!!!
80Truck
Oct 12, 2025 07:25 PM
MO transplant
Apr 23, 2023 11:58 AM
Sleaker
Aug 26, 2020 06:03 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
TDonkey
Jul 26, 2015 10:14 AM
