n00b wiring question
Old Sep 7, 2005 | 07:31 AM
yellowbird's Avatar
hey fellas, you guys seem to know your stuff around here, so who better to ask:
i have a 2001 tacoma reg cab, 2wd 4 cyl 5 spd. truck did not come with cruise control as an option, but id like to install it. i saw a part available on another website. my q's are: can the cruise control be installed if it wasnt an option? if so, wouldnt it be easier to pull the part from a junkyard?
thanks in advance.
sean
vr6pack@comcast.net
aolim: B4LLSDEEP
Old Sep 7, 2005 | 07:43 AM
jimbo74's Avatar
there is more to cruise control than a part....
adding it shouldnt be too hard if you get all the parts off the donor
welcome to the site
Old Sep 7, 2005 | 07:58 AM
yellowbird's Avatar
yea i figured it had to be more that just adding a new tree arm....what other parts would i need from the donor?
Old Sep 7, 2005 | 08:13 AM
celica's Avatar
If you are pulling it off a donar car you will also need the control box under the hood, cable to tht e throttle body & the TB linkage. The cruse uses a double pull system instead of the single (ie two cables). I am unsure if there are other wires that run to the ECU, maybe someone else has that answer??
Matt
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
