3rd Gen grab handle... you have one?
Old Oct 29, 2005 | 06:49 PM
98LimitedCustomized's Avatar
I just notice on my 98 Limited I have one on the A pillar but nothing up above the window like on the passenger side. However, I can see "through" the headliner that there are two possible holes where a handle can go. Anybody have any help on this? I doubt I'd need one since I have the giant round one I usually hold on to "some call it a steering wheel" but if there were holes already there I'm sure I could dream of something I didn't need to put up there, to put up there.
Old Oct 29, 2005 | 06:54 PM
4Crawler's Avatar
Usually you can just get another handle and screw it on. I did that on my 1st gen and it fit perfect:
http://www.4crawler.com/4x4/CheapTri...abHandle.shtml
One of the benefits of the world-wide distribution, LHD and RHD versions would need handle mounting holes for both sides.
Old Oct 29, 2005 | 07:04 PM
HOJU's Avatar
I noticed the same thing a couple years ago and just went down to the dealer, bought one and put it in...
Old Oct 29, 2005 | 07:05 PM
so you guys are saying there is indeed some tapped holes behind the headliner? I'd assume the same as the other side... wonder why they went to the trouble of drilling but never put them in?
Old Oct 29, 2005 | 07:13 PM
HOJU's Avatar
I'm guessing they just left it off thinking that as the driver you have the steering wheel to hold on to, but just go down and buy a handle, and put it in, you'll have two handles on each side.
oh yeah, and remember that over in Japan it's reversed, so they'd need that bracket on that side-
Old Oct 29, 2005 | 07:19 PM
4-RUNNIN' FREAK's Avatar
I was always thinking they left it off on that side so the driver doesn't whack his/her head on it.
Old Oct 29, 2005 | 07:23 PM
HOJU's Avatar
that's another possability, i've never done it, but i prob. will now that i said it-
Old Oct 29, 2005 | 07:42 PM
Ah yeah, I'd say you're right on with the Japan comment.... I bet the body shell on the Hilux and 4Runner start together...
Old Oct 29, 2005 | 08:16 PM
garrett1478's Avatar
in case you want to order online...
Grab Handle
Toyota P/N: 74610-16010-E3 (Grip)
Toyota P/N: 74617-16010-E7 (Plugs, 2 required)
Toyota P/N: 90159-60254 (Screws, 2 required)
Old Oct 29, 2005 | 09:29 PM
Noliwan's Avatar
You are absolutely correct on the holes on the drivers side for that grab handle-- I installed one awhile back when I put my A-pillar dual gauge pod in--- Very simple install just order the correct part & color to match your vehicle from TOYOTA...
You can even just pull the one from the passenger side and install it just to see how it looks...
Old Feb 7, 2009 | 10:08 PM
Ron Helmuth's Avatar
is it safe to say that if the grab handle is removed from the A pillar it could be reused over head and just transfer all parts?
Yes I see how old the thread is.... I search I search!!
Old Feb 7, 2009 | 10:15 PM
KZN185W's Avatar
the one on the A-Pillar is longer and has a somewhat different shape from the one on the headliner.
Old Feb 7, 2009 | 10:16 PM
MillerPKA's Avatar
i believe so, i have them on all points i can check in the morning. and if you're looking i'll probably be selling mine, i plan on making custom soft handles soon
edit: guess someone got the drop, oh well still for sale if interested
Old Feb 7, 2009 | 10:22 PM
dammm you guys are quick! MillerPKA thanks for the offer maybe I can scavenge one up here first but I will keep you in mind.
And I always enjoy I think it is your action pictures with Blake and some other fine rides down there.
Old Feb 7, 2009 | 10:31 PM
MillerPKA's Avatar
thanks man, no rush on the handles they'll be here for a while. the rigs being featured over at tundra headquarters sometime this month he may use some new badass shots from some runs last month.
also, keep an eye our for the aforementioned custom handle mod. if i can get some steady specifics down i'll post a write-up, should be a pretty cool addition
Old Feb 9, 2009 | 09:52 AM
a simple glance and I should have known
thanks KZN185W
doh it is blatanly obvious now that I look at them both-the roof mount ones are shorter.
Are you guys sure it is pre-tapped/drilled on the drivers side head area? I don't feel anything through the headliner....
Old Feb 9, 2009 | 12:05 PM
Rock Slide's Avatar
Mine was pre-drilled. I could somewhat "feel" the hole.
I went down to a local junk yard and picked up a passenger side handle for $3. It mounted perfectly to the hidden driverside holes.
I believe every 4Runner since inception had the driverside headliner "oh crap" handle holes pre-drilled simply b/c some 4Runners were offered in left hand drive, the others, right hand drive. Heck, my previous '86 4Runner even had the holes pre-drilled, hidden behind the headliner. I did the same "handle mod" to that 4Runner too.
Old Feb 9, 2009 | 03:14 PM
thanks RockSlide I will have to feel around a bit more for that.
Old Feb 10, 2009 | 01:51 AM
KZN185W's Avatar
i could also feel the two holes in mine. the nut was pre-welded behind each hole.
Old Aug 23, 2010 | 09:17 PM
jaaydee's Avatar
I just found this thread as I am wanting to add a handle above the drivers door. My local dealer told me there weren't holes there, but i can feel them. Going by this thread, I should be good to punch holes in the head liner and bolt on the handle.
The bigger problem is finding the handle. At this stage, it seems like all the junk vehicles have been picked over. Does anyone know where to find NOS handles?
Thanks for your help,
Jerry
