2nd gen OME prob... shock fouls upper bumpstop
Old Oct 24, 2005 | 04:59 AM
nrgetic99's Avatar
Just got done installing my OME set up.
N98 - front
N72F - rear
OME 900 springs
Steering stabilizer.
The front shocks foul the forward upper factory bumpstop at full droop
with the sway bar still connected. (in short, full droop per factory specs).
For now, I have removed the bumpstop and will prolly use this as a chance to replace with energy suspension low profile pieces but anyone else have this ?
I could make the factory ones fit with a little grinding of the flange but I had not read this from anyone else.
I wonder if my cams on my lower control arm are all the way in for some reason ? When I get an allignment, I will be interested in how much camber I have.
David
Old Oct 24, 2005 | 05:03 AM
FilthyRich's Avatar
I know you don't waste any time modding a truck I don't have an answer, but if I can help let me know. I have some wheels for that newly lifted truck too.
Post some pics
Old Oct 24, 2005 | 06:03 AM
nrgetic99's Avatar
Post some pics
I plan on posting pics as soon as I am done.
If my new VAFR arrives tonight, I will drop by....
.... my truck has been on square wheels for the last 7 days
David
Old Oct 24, 2005 | 06:18 AM
Godzilla's Avatar
you can go with the ES low profile bumpstops. That is what i ran on mine with your same setup and is common among others with this setup. i think the prt number is 9.9102 and here is a link to cebby's write up. https://www.yotatech.com/~corey/tech...tops/cebby.htm
do you plan on putting bj spacers? if so you may want to keep your stock ones on, or you will have to add washers to the es ones to raise them up. just lookin ahead.
Old Oct 24, 2005 | 06:22 AM
nrgetic99's Avatar
I just ordered the ES ones from Summit this morning as I got a little mad at the stock ones when I removed them....they won't go back now
No plans on BJ spacers yet...lets see how she sits once the OME's have settled down.
David
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
vanion2
Jul 29, 2015 06:17 PM
KyleT
Jul 21, 2015 07:54 PM
Steezy96yota
Jul 6, 2015 10:00 AM
